Thanks Thanks:  0
Results 1 to 10 of 10
Thread: Stern ghostbusters vpx issue
    Dec 2017
    AL
    7
    0 Post(s)
    2 Post(s)
    United States
    I have installed ghostbusters twice now and same issue. I keep getting failed to load dll error. When I launch the table the backglass comes up and then error. When I test the rom in vpinspa a black box comes up and then same error failed to load dll. Any thoughts? Thanks Tom
    Attached Images Attached Images
    Dec 2005
    Gold Coast
    3,257
    165 Post(s)
    299 Post(s)
    I had the same error but for the life of me I cant remember what I did
    Pinball Meets...I love em
    Nov 2006
    Tasmania
    532
    3 Post(s)
    20 Post(s)
    I think you have to install Microsoft visual c++ 2010 and 2012 redistributable packages.
    Oct 2005
    Croydon, VIC
    1,932
    87 Post(s)
    321 Post(s)
    I recall having the same problem and I think it was because i hadn't run the INSTALL from InstallVPinSPA.EXE in the VPinSPA directory. Maybe do that with yours - it won't hurt to run it again if you already HAVE installed it.
    Your paths and file locations look good, so the only other thing it may be is the Microsoft Visual C++ packages as @63wizz suggested.
    Dec 2017
    AL
    7
    0 Post(s)
    2 Post(s)
    United States
    finally got it working, it was the c++ files. now I wiped it to install 64 bit OS and same thing happening. I have 2010 and 12, I also have 08 and 13. would they cause an issue
  6. #6
    Oct 2005
    Croydon, VIC
    1,932
    87 Post(s)
    321 Post(s)
    Try the 2013 redist and see how you go.
  7. #7
    Dec 2016
    NL
    1
    0 Post(s)
    0 Post(s)
    Netherlands
    Tonight I found the solution for this problem (at least in my setup).
    GB was working fine when I did install it the way it (once) was described but when I did a full new Win10 install I got the .dll loading error, both in VPinspa when testing the table and also (of course then)( when trying to run the table in VPX.
    Tried e-ve-ry-thing messing up my total Win10 and VPX install severall times so that took me 2 days to be back to the statting point but...
    THIS EVENING I GOT IT WORKING!
    The trick is (as mentioned before): install the C++2012 x86 version (although your machine might be running Win10/64).
    You can (safely) find it here at Microsoft:
    https://www.microsoft.com/en-us/down....aspx?id=30679
    After this (and I did a reboot after installing) the test in VPinSpa worked and after that, also the table in VPX worked again!
    Happy Playing GB!
  8. #8
    Dec 2017
    AL
    7
    0 Post(s)
    2 Post(s)
    United States
    wow should have read this last night. i spent all day trying to figure the same thing out. i just changed my OS to 64 bit too and assumed that everything else should be 64 bit...….not pinballx, not c++...wonder what else
  9. #9
    Dec 2017
    AL
    7
    0 Post(s)
    2 Post(s)
    United States
    now GB is not working again. Rom checks fine but when I load the table it starts loading and then quits. If I deselect external dll on the rom the table loads fine but I am having a different issue with that...
  10. #10
    Oct 2005
    Croydon, VIC
    1,932
    87 Post(s)
    321 Post(s)
    Did you reinstall everything as per the "instructions" that (I think??) are with the GB files?
  1. VPGL 11 Game 3: Ghostbusters (Stern 2016)
    By Bishop83 in forum VPGL Tournament 11
    Last Post: 16th October 2018, 02:54 AM
  2. Replies: 13
    Last Post: 30th November 2017, 10:01 AM
  3. Ghostbusters Pro flipper issue
    By Replay in forum Arcade Technical and Repair Questions
    Last Post: 18th November 2016, 08:27 PM
  4. Ghostbusters. Would you buy the next Stern.
    By JOKERPOKER in forum New Pinball Discussion
    Last Post: 27th March 2016, 06:40 PM
