Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Thread: bally replacement boards
    Nov 2009
    bluemountains
    319
    5 Post(s)
    15 Post(s)
    https://cointaker.com/products/75-84...tern-mpu-board
    I have a Matahari aith intermittent problems - CPU rebooting and game starting over amongst other freezing.
    Are these MPU replacements a simple drop in? For $200 it might be a cheap fix.
    thanks
    George
    Mar 2013
    Truganina, Victoria
    7,259
    373 Post(s)
    2652 Post(s)
    its not $200.. is USD200 plus freight plus gst.. more like 350.
    if you want a drop in MPU you can buy an alltek board locally https://www.pinballspareparts.com.au/ultimate-mpu.html
    or get @Skybeaux to fix yours
    probably well worth reconsidering the assumption that the mpu is the issue as well....
    Nov 2007
    Illawarra NSW
    7,524
    125 Post(s)
    1676 Post(s)
    Quote Originally Posted by wiredoug View Post
    Yep, more likely connectors rather than the mpu.
    Best off sending the mpu and driver board to ken for an overhaul. New headers, IC's, caps etc.
    Aug 2009
    Shepparton Vic
    4,949
    242 Post(s)
    1627 Post(s)
    Check for battery damage on the board too.
    Feb 2006
    South Australia
    1,205
    21 Post(s)
    82 Post(s)
    Quote Originally Posted by lentildude View Post
    thanks
    George
    I had the same issue with my board. My board looked in ok condition so I sent it to Ken to fix. He's a straight up guy and will tell you if its worth fixing or not.
    Dec 2016
    Barden Ridge NSW
    3,185
    164 Post(s)
    1178 Post(s)
    Make sure the center harness saddle clamp is supporting the weight of the main head wiring harness and isn't just looped through it. Without this simple part doing it's intended job results in the board wiring connectors having to hold the weight of this harness.
    Also check the ground is nice and tight. Seeing as your machine is booting, my money is on one of these issues being your problem however dodgy rom sockets can cause similar problems as well. Something Ken will fix and I'm sure Ken will find other things that greatly increase reliability.
    Money very well spent.
    Nov 2009
    bluemountains
    319
    5 Post(s)
    15 Post(s)
    thnx for comments. Will look a little deeper before considering a "brain swap.."
    Dec 2010
    1,716
    82 Post(s)
    537 Post(s)
    to answer your question, yes they are a simple drop in.
    you set a dip switch bank to suit your Mata Hari.
    you may also need to upgrade your solenoid driver board if you haven't already.
    without a fast, clean, solid 5VDC supply at power up it will never start the MPU booting.
    Nov 2009
    bluemountains
    319
    5 Post(s)
    15 Post(s)
    Rich, my rectifier board is terrible. Who in the group sells the rectifier boards? I will need the connector sets too as some coin op 30 years ago soldered wires directly to some of the pins.
    Dec 2006
    Central Coast,NSW
    9,611
    287 Post(s)
    1845 Post(s)
    New Zealand
    YUK!!!!. This is so often the case
    @Tangles sells a very nice replacement board here on AA https://www.aussiearcade.com/showthr...gles-Pin-Parts
    If it was me I'd be replacing that board 1st before chasing any other board "problems". They are 99% always shot with hacks and getting very tired. You'll be amazed how much better the game will now work.
  1. Rottondog replacement boards
    By pinballaddicted in forum Pinball Restoration Questions and Help
    Last Post: 20th February 2017, 07:59 PM
  2. PI all-in-one electronic replacement boards
    By voodle in forum Pinball
    Last Post: 23rd January 2017, 05:21 AM
  3. Replacement Processor Boards
    By gordo in forum Pinball Technical and Repair Questions
    Last Post: 19th January 2017, 07:23 AM
  4. Williams pinball replacement PCBs (boards)
    By cejay in forum Pinball Technical and Repair Questions
    Last Post: 14th October 2015, 08:31 PM
