Likes Likes:  0
Results 1 to 7 of 7
Thread: Berzerk - Original Stern
    Oct 2005
    Redlands
    19,272
    164 Post(s)
    1979 Post(s)
    Heres another one i just fixed for your reading pleasure...
    I bought a dedicated LAI Berzerk cab off John, defiantly a lot of work but It will be worth it.
    Berzerk is a prick of a board set to work on easily the largest I've seen thus far.
    Not including the PSU and filter board (which I won't be using) there are 5 pcbs that make up Berzerk
    ZPU-1000: Main CPU board.
    BSC-1000: Colour overlay pcb.
    VFB-1000: Video Board
    SB-1000: Sound FX
    VSU-1000: Voice Generator Board
    Was a real learning experience for me. I'll list the problems with each individual boards, i left the 2 sound boards off while working on it.
    ZPU-1000
    I'll be making a JAMMA harness for this so this is the pins i used for this board. The pins are clearly
    marked from right to left 1-10
    1 - book keeping.
    2 - Ground
    5 - +5
    9 - +5
    Rest are not used, there is pins there for -5 and +12 but are not needed unless you use some queerbo roms.
    What a mess, I've read battery acid damage on these pcbs are common and this one was no exception. I was very lucky that all tracks were intact.
    All the roms were missing on the pcb so replaced those, fired her up...nothing the test LED stays on.
    First things you always check with a dead pcb is the clock(pin 6) and the reset(pin 26). Clock was pulsing fine but reset was stuck low.
    Did some reading on the net about this, when using a switch mode power supply you have to run a jumper across the diode @ CR26
    OK now the LED flashes once which means by going from the manual a rom issue.
    Going through all the roms I found the rom @ C1 pin 23 was dead, this rom is the test rom and that pin leads back to the CPU test Jumper. The jumper had cold solder joints and the track to the socket was pretty bad. I decided to replace the socket fixed the trace.
    Right game is going through its test cycle, i get 3 LED flashes which means rom/rams ok the next test is suppose to be the VFB-1000 but it stops after 3.
    At this point I noticed a lot corrosion on the interconnect pins on the cpu and video boards so I replaced them, no change though still stop at 3 flashes and nothing on the screen at all.
    After game working Issues.
    Problem: Game boots up with 5 high scores all with random garbage and 37 credits.
    Fix: Don't know if it should do this to begin with but I solved it by adding in a 3.6v nicad battery going into the book keeping and resetting all the values.
    BSC-1000
    Pinout
    2 - +5
    4 - Blue
    5 - Green
    6 - Red
    No issues with this PCB, took out all the 2114 rams and tested them on other boards all worked fine.
    VFB-1000
    Pinout for J8, 12 pins
    1 - Ground
    3 - Comp sync
    7 - +5
    8 - +5
    9 - Ground
    11 - Ground (normally -5 for 4027 rams, not needed for 4164 but I ground so its possible to also use 41256)
    12 - +5 (normally +12 for 4064)
    J5 - 10 pins
    1- Ground
    6- Fire
    7- Down
    8- Up
    9- Right
    10- Left
    J6 - 10 pins
    1- Ground
    2- Coin 1
    3- Coin 2
    4- Coin 3
    9- P2 Start
    10- P1 Start
    Let me start by saing **** when those old crappy 4027 rams go they get super hot and I got the blisters to prove it!
    The 4027 ram is pretty much the same as the common 4116 ram used on Defender and many other old pcb but has 1 less address line ad a CS(Chip Select) pin, they also use 3 voltages +12, +5 and -5.
    I decided before I did any diagnostics to replace all the sockets for the rams and the 2 big logic chips(74ls181's).
    I've also decided to do away with the 4027 rams and use 4164 rams which only use +5 thus running much cooler, to do this i had to remove the following caps used on the +12 line c77, c88,c106, c66, c100 and c82.
    I couldnt get the pcb to work so I ordered some of the rarer chips off the PCB from futurelec namely 74ls01,181,155,75 and some cmod chips that are used on the sound board 4051, 4053.
    With the new chips at hand I changed the 2 74ls181 which had broken legs, still nothing the rams outputs were dead.
    Doing some poking around with the logic probe i found a suspect counter 74ls161 @ 4G, piggy backing another chip on top gave me stuff on the screen
    Replaced the chip game fired right up now onto sound.
    SB-1000
    J3 Pinout
    3 - Audio in. Goes to the VSU pin 6, sound input for voice board.
    4 - +5
    6 - volume control (connected to 50k pot)
    7 - +12
    8 - volume control (connected to 50k pot)
    9 - Speaker -
    11 - Speaker +
    12 - +12
    There are a few uncommon chips on this PCB some I managed to get from futurelec (4053, 4051 and MC6804) a couple I had to get from Rockby (cheers The Prof for the link) which are MC14175 and MC14562 both of which were not needed in the repair but handy to have to keep my Berzerk going for many years to come. For 10 of each of these it cost me $50 so not cheap either!
    Problem: missing 2 sounds, the shock sound when you run into a wall and the sound when you shoot a robot. the fire sound was ok
    Fixed: 3 chips at fault all in the noise generator section of the pcb. 4053 Cmos @ B6, 74ls74 @ B8 and 74ls86 @ A8. All sounds now perfect.
    VSU 1000
    Pinout
    1- -5(says -12 but -5 works fine)
    5- +5
    6- Audio out. Connect to pin 3 of the SB 1000
    This pcb i worried about the most because it has the voice generator chip TSI S14001A, only thing missing was a 2716 rom @ 2C. Programmed the rom up works fine! woohoo!
    If anybody knows where I can buy a spare S14001A please let me know!
    On the To Do list
    Wire up control to harness and document...DONE
    Berzerk Frenzy 2 in 1 mod.
    Mar 2007
    New Zealand
    7,258
    45 Post(s)
    296 Post(s)
    Congrats!
    A game well worth saving!
    Jan 2006
    Queensland
    1,581
    11 Post(s)
    21 Post(s)
    **** me I wish all boards had nice screen printed areas like that describing what each parts for... how handy...
    Always interested in Retro and Current gaming
    https://www.gamedude.com.au
    Nov 2005
    Drouin VIC on the move ;)
    7,903
    33 Post(s)
    354 Post(s)
    Good one Trav I look forward to havening a bash on it at the next shitcade meet I attend
    The best action is wrist action!!!!!!
    Oct 2005
    Redlands
    19,272
    164 Post(s)
    1979 Post(s)
    This has been sitting in the corner dead for about year and after Game On i got motivated to fix it.
    Problem: The status LED flashes twice with 2 beeps from the speaker at the same time.
    Fix: Turned out to be the rarest part on the board 6513l-9 CMOS ram. luckily I have a spare CPU board which had one on so I'll have to track more down. Can also use 6514's as well.
    Mar 2006
    Brisbane, Australia
    11,598
    192 Post(s)
    1455 Post(s)
    Get cracking slacker. It was sad to see it sitting there all dusty and lonesome on sunday
    Brad
    Oct 2005
    Redlands
    19,272
    164 Post(s)
    1979 Post(s)
    yeah yeah maybe one day......
  1. Original Tatio Jungle King/Elevator Action
    By Arcade King in forum PCB and Monitor Repair logs
    Last Post: 24th May 2010, 06:35 AM
  2. Can Stern survive
    By buzz66 in forum Pinball
    Last Post: 4th October 2007, 02:54 PM
  3. What were Stern thinking?
    By Bumper in forum Pinball
    Last Post: 29th August 2007, 01:00 AM
  4. Scratch Built Galaga Project
    By Hoopstar in forum Video Arcade Restorations and Projects
    Last Post: 12th May 2007, 09:00 PM
  5. Original versions of Star Wars on DVD coming soon!
    By Mickey Juice in forum General Chat
    Last Post: 5th May 2006, 05:11 PM
