Page 1 of 2 12 LastLast
Results 1 to 10 of 19
Thread: Long-swinging tilt bobs
    Mar 2016
    Queensland
    1,766
    89 Post(s)
    626 Post(s)
    The other day, I had a game on Party Zone. I made a move and tilted. The game had previously been tilting at surprising moments, without provocation, and I had a feeling that the tilt bob might off-centre. Immediately after I tilted, we opened the coin door and had a look. Sure enough, the tilt bob was swinging. I started my stop watch. It was still swinging noticeably three and a half minutes later!
    The issue wasn't that the tilt bob was off-centre (it wasn't), but that the bloody thing just kept swinging forever.
    Here is a novel approach at stopping the motion:
    And a follow-up video:
    But, rather than hitting the machine, I think the following is a much more elegant solution:
    I don't think dampening the tilt bob will influence how easy/hard it is to tilt the machine. Just adjust the tilt to the desired sensitivity as usual.
    I really like the dampening idea. It's much better than the endless waiting around at tournaments after someone has tilted or walks away with a double danger so the tilt bob can settle. The waiting takes the momentum out of things, and no-one likes having to do it. And, after what I learned from the 3.5 minute timing experiment, with an un-dampened tilt bob, I'm now inclined to wait two minutes instead of my usual one minute…
    Michi.
    May the pinballs tumble in your direction!
    Mar 2017
    2,411
    57 Post(s)
    828 Post(s)
    Live on Twitch, Tuesdays 6pm + other random times | twitch.tv/ajfclark | You can vote for what machine I play, click here, follow my channel and type '!vote' in chat for details | Movember: mobro.co/ajfclark
    Apr 2015
    SA
    351
    21 Post(s)
    134 Post(s)
    Never bothered testing this, might be worth timing it, but I believe that mounting a plumb bob upside-down should make it stop swinging a lot quicker. The weight of the plumb bob is then higher up on the shaft much closer to the pivot point
    www.pinballmuseum.com.au
    www.facebook.com/pinballmuseum
    Subscribe to the quarterly newsletter to keep up to date with everything going on at the Australian Pinball Museum: www.pinballmuseum.com.au/?p=Newsletter
    Dec 2006
    Central Coast,NSW
    9,611
    287 Post(s)
    1845 Post(s)
    New Zealand
    I can't remember the last time I tilted a pin that was set up as medium/normal play.
    I respect that some players will test the limits on how far they can push a 135kg machine around BUT I treat my beasts and even the ones on site with a little and I mean little nudge.
    I've seen some shockers on security cameras when abusive players push them into the wall to save a drain. I've seen in person a player play an onsite game with the owners next to him slide the machine 6" and they didn't raise an eyebrow that this clown was trying to destroy their 2 week old metallica slamming into the wall when the ball drained.
    Mar 2017
    2,411
    57 Post(s)
    828 Post(s)
    Quote Originally Posted by Brk_oth View Post
    Also means if it loosens that it makes the tilt tighter and the bob can't fall off.
    Mar 2016
    Queensland
    1,766
    89 Post(s)
    626 Post(s)
    This thread wasn't meant to be about machine abuse, but about cutting down on the wait times after someone has tilted. (With a dampener installed, the tilt sensitivity can still be adjusted to any level that's desired.)
    The issue with long-swinging tilt bobs is that, if player 1 gets a warning or tilts (normally, not abusively), that can easily affect player 3 or even player 4. With a dampener, the tilt bob stops swinging more quickly, making things fairer and cutting down on wait time between balls.
    Michi.
    Mar 2017
    2,411
    57 Post(s)
    828 Post(s)
    Quote Originally Posted by Michi View Post
    Michi.
    Yup. That "The Pinball Tilt" video does an excellent job of explaining why too. It's interesting to compare the motion of a hook and bracket setup vs the old push nut on a rod setup.
    eg.
    vs
    The push nut style doesn't settle the same way, nor does it settle faster on front to back motion compared to side to side like the hook and bracket style.
    It also appears in the Bally Parts Catalog like that at some point:
    Aug 2015
    Queensland
    450
    86 Post(s)
    107 Post(s)
    I remember a couple year ago they put some ear plugs in to dampen the bob from swinging too much at acs
    Mar 2016
    Queensland
    1,766
    89 Post(s)
    626 Post(s)
    Yep. And it costs more to make, so no-one uses it
    Michi.
    Quote Originally Posted by JoeSoap View Post
    Nice to hear! It's a change for the better, IMO.
    Michi.
    Mar 2017
    2,411
    57 Post(s)
    828 Post(s)
    I actually think the side to side bias on the hook style is an advantage @Michi. Side to side stuff tilts, little front to back bumps don't. That seems like a good thing to me.
    The settling into one of the 2 major axis and then tilting is less good.
  1. Just my two bobs worth
    By Rob1966 in forum Pinball
    Last Post: 18th March 2015, 03:42 PM
  2. Frogger - A long, long road.
    By knight76 in forum Arcade
    Last Post: 30th January 2012, 07:45 PM
  3. Game-swinging - Trade games and gals!
    By knight76 in forum General Chat
    Last Post: 15th November 2011, 09:08 PM
