Page 1 of 8 123 ... LastLast
Results 1 to 10 of 73
Thread: Taito Speed Race resto
    Sep 2018
    victoria
    79
    3 Post(s)
    13 Post(s)
    So here they are, my two latest boondoggles. Speed Race and Space Rider, they'll side up nicely next to my mame machine once I (hopefully) get them back in operating condition. For now the best thing I can say about them is that they are complete, without any obvious evidence of electrical carnage taking place inside. In fact the pinball machine looks surprisingly good inside for something that is a decade older than I am. It looks unmolested with a mint backglass, but the same can't be said for the Speed Race cabinet. It appears as if someone has added an aux power supply circuit for the CRT, although I'd be lying if I said I knew what these things are supposed to look like inside.
    I've decided to embark upon the restoration of the Taito first as it seems less daunting at this stage. This thing was sold to me as a 'dead screen' deal, but I'm not so sure that this is the case. When I power it up I get a dead screen, that familiar crt whine, a glowing neck and the time/score panels seem to be functioning. So nothing on the display and and no sound. One thing I did notice was when I turn off the power, a white dot appears in the middle of the CRT before fading out.
    I do intend spending the rest of the night combing out of this forum whatever chunks of wisdom I can find, but a little kick in the right direction would be much appreciated. Does this smell like a CRT fault or an issue in the logic somewhere?
    Jun 2008
    Brisbane, QLD
    2,677
    261 Post(s)
    517 Post(s)
    Here's a scan I did of the original manual...
    https://drive.google.com/open?id=0B0...lVyTVZmMjJ1RGM
    Sep 2018
    victoria
    79
    3 Post(s)
    13 Post(s)
    Sweeet. Thanks dude.
    That's just what I needed to sort out this rat's nest. The more I look, the more I find. Someone had been keeping this thing on life support, doing surgery with whatever was close by. I think I can see at least 3 'eras' of wiring here.
    Sep 2009
    westlake, Brisbane
    2,636
    195 Post(s)
    463 Post(s)
    Welcome to the world of arcade restoration
    Sep 2018
    victoria
    79
    3 Post(s)
    13 Post(s)
    Cheers mate.
    It'll make a nice change of pace from cars and bikes.... At least these things aren't covered in 'vintage' grease. And I get to learn all about digital electronics.
    I have kinda been putting it off. In the workshop, once things get beyond 'replace the blown cap', it's time to order a replacement. Somehow I don't think that's going to be a viable option here.
    Sep 2009
    westlake, Brisbane
    2,636
    195 Post(s)
    463 Post(s)
    Quote Originally Posted by SeaJay View Post
    Cheers mate.
    Mate, you have exactly the right attitude for this sort of stuff.
    There are many instances where you really have to find a ton of previous info / failures and fix it yourself.
    The Taito has plenty of support and info, the Atari, not so much.
    I applaud your enthusiasm and I'm sure there will be a ton of enthusiastic supporters on the forum here where any questions can be answered.
    I am not an arcade guy but I think your Taito problem may be a board issue rather than a display issue.
    Neck board lights and video decay dot indicates to me that it thinks it's doing what it should, however I am not an arcade guy.
    Ask me a pinball question, (not Atari )
    Sep 2018
    victoria
    79
    3 Post(s)
    13 Post(s)
    Quote Originally Posted by raysco View Post
    I'm inclined to agree. At this stage I'm hoping that it's an issue somewhere between the board and the CRT. Who knows, it's a mess in there, I might get lucky.
    Jun 2008
    Brisbane, QLD
    2,677
    261 Post(s)
    517 Post(s)
    More than likely a logic board issue, you can double check by connecting the video output from the PCB to any TV (CRT or LCD will work) via the AV input. I've never tried it but I'm guessing that you could conversely connect a console with AV output to the monitor input and see if it displays an image.
    Have you confirmed the board has +5v at the chips?
    Do you own a logic probe? It's essential if you plan to try to fix this board yourself but without a schematic or chip numbers it's not an easy task.
    I'm guessing that the PCB will have the writing on the chips sanded off, Taito did this in the early years to stop the game being copied. This makes it very difficult to know what's expected from the chip inputs and outputs.
    Below is the databook for Midway Wheels which is very close to Speed Race, there isn't a schematic available for Speed Race that I've been able to locate.
    Though not exactly the same, they share many similarities.
    https://drive.google.com/open?id=0B0...TJiRXR0djJVUVE
    Sep 2018
    victoria
    79
    3 Post(s)
    13 Post(s)
    That's a good place to start for sure. I'll see what I can work out in the morning. I haven't done any diagnostics aside from looking at it and plugging it in as yet. I'm still holding out hope that it could be something simple like a power supply issue, it looks like that whole side of things has been messed with.
    I did notice the sanded chips when I pulled the main board, thought it was odd. A logic probe is on my shopping list for tomorrow and I'm bracing myself for the dive into the intricacies of digital stuff. I figure this has to be a good place to start.
    Thanks for the data, I'll add it to my files. A schematic for this thing would be awesome, google found me one for the Atari in 0.000012 seconds....
    Jun 2008
    Brisbane, QLD
    2,677
    261 Post(s)
    517 Post(s)
    Jaycar sell a Logic Probe kit for $15 or you can order one from Ebay for about $30+
    https://www.jaycar.com.au/logic-probe-kit/p/KD6100
    This is the type I use.
    https://www.jpmsupply.com/Logic-Prob...00-p/80311.htm
  1. Taito Speed Race GP5 video
    By RaMpAgE in forum Arcade
    Last Post: 12th September 2013, 08:40 PM
  2. The first game: Taito Speed Race
    By taito in forum Introduction Forum
    Last Post: 12th January 2010, 09:55 PM
