• Enraged
  • Embarrased
  • Drunk
  • Down
  • Depressed
  • Crying
  • Crazy
  • Cool
  • Cocky
  • Bemused
  • Awesome
  • Annoyed
  • Angry
  • Amused
  • Friendly
  • Geeky
  • Godly
  • Happy
  • Hateful
  • Hungry
  • Innocent
  • Meh
  • Piratey
  • Poorly
  • Sad
  • Secret
  • Shy
  • Sneaky
  • Tired
  • Wtf
  • Thanks Thanks:  0
    Results 1 to 9 of 9
    Thread: Help with 1942 arcade ROM sizes
      d18c7db is online now
      This user has no status.
      Jul 2018
      Kalmar
      5
      0 Post(s)
      0 Post(s)
      Sweden
      Can a kind soul (perhaps someone who has worked on repairs on these boards) please answer a question for me.
      I need to know what the deal is with the ROMs on the 1942 video board (I don't have a real board or I'd look at it myself).
      The schematic of video board 02A on page 6/8 shows ROMs L1, L2 (labeled as 2764x2) and N1, N2 (also labeled as 2764x2) as having address lines A0..A12 which is normal and expected from 8KB ROMs.
      The problem is that all ROM dumps available online such as those used with MAME have these ROM files as 16KB each (which would imply 27128 ROMs)!
      So on a real board then, either the ROMs are really 16KB but only half of them are used or the schematic is wrong, in which case, where is the ROM address line A13 (pin 26) connected to?
      Cheers
      Alex
      Womble's Avatar
      Womble is offline
      is The makers may make and the
      users may use, but the fixers
      must fix with but minimal
      clues
      Happy
      Oct 2007
      Melbourne
      5,381
      58 Post(s)
      355 Post(s)
      This happens a number of times across Arcade history, as the price sweetspot of EPROMs trended downwards. EPROMs were very expensive parts, but at the cross-over point they bought whatever was the cheaper option on the day procurement were hunting. You see the same thing with RAM chips, and also this searching for the cheapest option with TTL ICs, that's why you see such a mix of manufacturers on a PCB, rather than every single 74LS chip from the same manufacturer (they all made the standard range after all), it just came down to price, and saving 2 cent on a chip by choosing a different manufacturer, across a PCB production of 10,000 boards was worth doing.
      PCBs produced at the time these sweet-spot crossovers happened were often designed so they could take both sizes, so in the case of 1942 the board could be configured to take either two 2764s (using both sockets), or a single 27128 only using one socket, whatever option was cheapest for that run of 10,000 PCBs or so.
      If you look at the pinout of both 2764 and 27128s they are both 28 pin EPROMs, the only difference being pin 26, which is NC (not connected) on 2764 or A13 on a 27128.
      The schematics probably show the jumper which either takes A13 from the CPU direct to pin 26 on one of the sockets, or directs it to an OR gate on a TTL chip that feeds the Output Enable pins to select between two 2764s (via an inverter on a split output)
      Often later board runs, once a crossover point had passed, would dispense with the second socket (saves a few more cents) and hardwire the jumper, but the spaces will still be on the PCB as redesiging the board was a very expensive option.
      So in the case of the MAME files it is just that the board that was dumped was using 27128s, but you can chop those files in half in a hex-editor and get the contents of the two 2764s.
      Sic transit gloria Atari!
      Jul 2018
      Kalmar
      5
      0 Post(s)
      0 Post(s)
      Sweden
      Thanks, that would make sense in principle but in this case the problem is that this doesnít apply.
      All ROM dumps are double the size so I have four 16KB ROMs that I need to fit in the space where four 8KB ROMs would go.
      I have also checked that each dump contains unique data so itís not like a 8KB ROM was dumped like a 16KB and the data is duplicated twice. This is also on the video board so the address doesnít come from the CPU but other logic. If it was the CPU board Iíd just hook A13 to address bus and hope for the best but on the video board I canít easily see what would provide this extra address line.
      There is the schematic. As can be seen AD6 feeds into A12 then AD7 is used as a bank select. I have four ROM dumps for L1,L2,N1,N2 each dump is 16KB. How do I connect 16KB ROMs according to that schematic? Why are the dumps 16KB each and not 8KB. Are there different hardware revisions? Is there a schematic for those ? Iím really confused.
      Anyone know the answer?
      Womble's Avatar
      Womble is offline
      clues
      Happy
      Oct 2007
      Melbourne
      5,381
      58 Post(s)
      355 Post(s)
      In that case you don't have the right ROMs for the PCB described by that schematic.
      What are you trying to do?
      Jul 2018
      Kalmar
      5
      0 Post(s)
      0 Post(s)
      Sweden
      All versions of 1942, 1942a, 1942b MAME ROMs have the same size 16KB ROMs. I haven’t seen any other versions.
      I’m doing a FPGA implementation. Main board works including sound. Video board shows garbled image (I wonder why heheh) so I’m still debugging that. I literally just finished transcribing the schematic to VHDL yesterday so I have some debugging to do.
      My question therefore remains, why are all the MAME ROM dumps for those ROMs 16KB when the schematic shows 8KB ROMs.
    6. #6
      ozfalcon's Avatar
      ozfalcon is offline
      is Active
      Aug 2012
      Sydney
      1,640
      28 Post(s)
      441 Post(s)
      Sorry, You checked the roms.....
      Ask at Mame irc, People there would be able to answer your technical details.
    7. #7
      Womble's Avatar
      Womble is offline
      clues
      Happy
      Oct 2007
      Melbourne
      5,381
      58 Post(s)
      355 Post(s)
      I suspect the schematic is just wrong, a lot of them have errors.
      I don't have a 1942 PCB anymore, otherwise I could buzz it out.
    8. #8
      Jul 2018
      Kalmar
      5
      0 Post(s)
      0 Post(s)
      Sweden
      Ok thanks guys. I’ll see what I can find out elsewhere.
    9. #9
      Jul 2018
      Kalmar
      5
      0 Post(s)
      0 Post(s)
      Sweden
      The MAME guys on irc reckon that A13 for those ROMs is provided by vover which comes from latch K6 on previous schematic page. Iíll give that a try.
    There are currently 2 users browsing this thread. (1 members and 1 guests)
    1. d18c7db
    1. Sega New Astro City Arcade Machine Lock Sizes?
      By 80's KiD in forum Arcade Machine Restoration Questions and Help
      Last Post: 20th September 2015, 09:07 AM
    2. t.v sizes
      By kosmokramer in forum General Chat
      Last Post: 21st July 2012, 07:36 AM
    3. ROM Sizes
      By Womble in forum Arcade Technical and Repair Questions
      Last Post: 28th May 2008, 04:52 PM
    4. sizes for cabinets
      By opm881 in forum Mame Cab Projects and Discussion
      Last Post: 30th March 2008, 10:29 AM
    5. 1942 artwork - Arcade alex?
      By philby85 in forum Arcade
      Last Post: 10th September 2007, 02:35 PM
