Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: CRT Monitor display with wiggly lines
    Jun 2018
    Queensland
    16
    3 Post(s)
    I have recently got a CRT monitor up and running.
    Previously I have this converter board which ran my Jamma board on a LCD screen:
    The CRT monitor has a VGA cable wired (and taped) up. I am trying to plug the VGA cable from the CRT in to the adapter and I have the following results below. If I use the CRT controls, the wiggles resize and move with the screen when making adjustments.
    I guess my question is that 1) Has anyone seen this before? and 2) Could it be the adapter causing this, meaning should there be a cable that goes from the Jamma RGB cable to the CRT?
    Here is what I get:
    Nov 2010
    Brisbane
    5,609
    155 Post(s)
    1337 Post(s)
    Is the CRT 31khz or 15khz?
    If it's 15khz, no need for the adaptor now. Ditch it and hook-up the board directly. It may require some rewiring, but there's no need for the adaptor anymore if you're going to run a 15khz CRT.
    Also, the VGA cable wired to the monitor may not be VGA, it could just look like one. If it's a 15khz monitor, it may just be a DB-15 plug that has been wired to take RGB-sync and ground.
    Jun 2018
    Queensland
    16
    3 Post(s)
    Hi Namastepat
    That sounds like the best option, I'm embarrassed to admit I do not know if it is 15khz or 31khz and on top of that I don't know how to find out.
    I think you are spot on with the cable though. I have removed it and taken a couple of shots of the cable and connector.
    It appears to go in this order:
    1) Red
    2) Red Ground
    3) Green
    4) Green Ground
    5) Blue
    6) Blue Ground
    7) H\V ?
    8) V ?
    9) ?
    10) Ground
    I figure I should be able to wire 1, 3, 5, and 10 to the Jamma video connector.. but which one should be 'sync' ? (which is a white wire from the Jamma video connector)
    And here is the current connector:
    Nov 2010
    Brisbane
    5,609
    155 Post(s)
    1337 Post(s)
    When it comes to specific wiring, I will pass it over to people who know more than I do.
    Basically, take a photo of the monitor chassis with a model number and other stuff visible and @Jomac will likely be able to ID the chassis. Or you can go to his website here and see if you can ID the chassis from the photos. That will let you know if it's 15khz or 31khz.
    http://www.jomac.net.au/services/monitors/
    The rewiring is beyond my skills, but someone on here will be able to let you know what needs to go from the JAMMA harness to the connector.
    Jun 2018
    Queensland
    16
    3 Post(s)
    No problem and thanks heaps for info you have provided.
    I would say it looks like it is a Ducksan 1301 Series. I have found a schematic which looks like it matches too, and according to this:
    Pin 7 = H Sync
    Pin 8 = V Sync
    And the Jamma Video connector has the following:
    RED
    GREEN
    BLUE
    GROUND (black)
    SYNC (white)
    Which leads me to the question about which Sync should be wired up to this connector (V Sync or H Sync) ?
    I still can't find whether it is 15 or 31 khz but here are the labels from the monitor:
    Sep 2012
    198
    6 Post(s)
    54 Post(s)
    Found this...
    http://www.pinball2000.de/pin2000_monitor.htm
    Try connecting the yellow and white wires on the monitor cable to the single white sync wire of the RGBS connector.
    Mar 2011
    Europe
    62
    11 Post(s)
    29 Post(s)
    That tube is for chassis that only do 15khz.
    connect jamma csync to h.
    Jun 2018
    Queensland
    16
    3 Post(s)
    I wired it directly, using sync H and unfortunately it didn't make any difference, the display remains sqiggly - I have noticed the squiggles change depending on what is on the display at the time. I managed to get hold of another board, (different game) and with using the same wire harness, there was no display distortion.
    The game board I am using with the monitor issue is Point Blank. Now I am wondering if this Point Blank requires a specific monitor to run on?
    I will try it with a different power supply tomorrow but I have my doubts that will change anything.
    Nov 2010
    Brisbane
    5,609
    155 Post(s)
    1337 Post(s)
    Point Blank is just a standard 15khz game, no specific monitor required. Might be a board fault, but it doesn't look like one. It looks to be more monitor related.
    Feb 2016
    659
    5 Post(s)
    180 Post(s)
    Connect both sync wires from chasis to the jamma one
  1. Just got Chassis Rebuilt - Green lines and washed out display?
    By SilentSausage93 in forum Monitor and Chassis Repair Help
    Last Post: 1st November 2016, 07:38 PM
  2. blured lines on monitor
    By abeswick in forum Arcade Technical and Repair Questions
    Last Post: 4th May 2014, 10:26 PM
  3. Scrolling lines over top of display
    By TREDLEY in forum Jomac
    Last Post: 30th October 2010, 11:41 AM
  4. 5'ish horozontal lines across top of monitor
    By Bikkies in forum Monitor and Chassis Repair Help
    Last Post: 19th March 2009, 04:36 PM
  5. Horizontal lines in monitor
    By wweumina in forum Arcade Technical and Repair Questions
    Last Post: 25th November 2008, 04:36 PM
