Results 1 to 8 of 8
Thread: Vintage HMV C211 TV Cap Replacement Equivalent Plessey EPC2266/Elna CE69W 2200uF 80VW
    Apr 2012
    NSW
    803
    18 Post(s)
    239 Post(s)
    Hey all,
    Looking to replace a capacitor on a 1976 HMV Consulate (C211 Chassis).
    The faults guide recommends replacement of C241. It says the original equipment was a Plessey type EPC 2266 2200uF. It also goes on to say later manufactured sets replaced them with "Elna" type CE69W (P) EMI Part No 2692071 (2500uF 80VW)
    Can anyone here recommend a modern equivalent that can be purchased readily at a reasonable price?
    Cheers,
    Mark
    Why does Google show a thousand hits just after you've posted on a forum when before you can't find anything...
    I assume something here will do.
    https://au.rs-online.com/web/c/passi...414,4294519026
    Jan 2014
    725
    13 Post(s)
    123 Post(s)
    What's the fault?
    Apr 2012
    NSW
    803
    18 Post(s)
    239 Post(s)
    Too of screen is down with some fold over.
    Jan 2014
    725
    13 Post(s)
    123 Post(s)
    Those old TVs are great.
    Yes one of those will be ok just don't go under the 80Volt rating.
    Just be aware of the spacing of the pins so they line up on your board.
    Do you have a schematic too?
    Apr 2012
    NSW
    803
    18 Post(s)
    239 Post(s)
    Itís a friend of mineís set. Unfortunately I live two hours away.
    We do have a schematic and a common faults guide but would be stoked to find any more info if you have access.
    Iíll share what we have on google drive and will up some links.
    Apr 2012
    NSW
    803
    18 Post(s)
    239 Post(s)
    https://drive.google.com/open?id=1Fg...Pj9sotmeYqrRvs
    Iíll keep this folder up to date.
    Jan 2014
    725
    13 Post(s)
    123 Post(s)
    Great info, thanks for sharing. Your C241 2200uf cap is the 60volt supply filter for the vertical section. Definitely a good place to start as suggested. Also mentioned as you probably already know is R248 75ohm (it seems from your schematic) which is in line with the 60 volts after the supply diode.
    I'd also look at C318 10uf in the feedback part of the vertical section.
    With both the schematic complete with voltage reference points and your fault lists, you've got a great head start to fixing the fault.
    Let us know how you go.
    Apr 2012
    NSW
    803
    18 Post(s)
    239 Post(s)
    Agree that R248 and C318 are the next best targets but until I have further information about the parts there is not much I can do about those.
    My friend will take pictures when he gets the chance and we should be able to determine the correct part for C318. At the moment I just have "10uF Capacitor" to go by. The schematic shows a signal pattern that goes up to 66V for a test point just beyond the cap so something like an 80V?
    Perhaps these: https://au.rs-online.com/web/c/passi...026,4294826632
    For R248 I know it's 75R but I'm not sure of the wattage. If it's 60V/75R that is 0.8amps which would be 60V*0.8A = 48W. So a 50W or better resistor required?
    My friend is still a novice but can hold a soldering iron so we're trying to bight off things that can be easily chewed for now. Replacing C241 will be an appropriate starting point (even that may have its challenges). Hopefully we get lucky.
  1. LM/CA3080 Equivalent
    By Kaizen in forum Arcade Technical and Repair Questions
    Last Post: 13th May 2017, 01:08 PM
  2. Australian equivalent to a 3/8A fuse?
    By correva in forum Pinball
    Last Post: 23rd January 2014, 01:03 PM
  3. Bally MPU replacement equivalent chip for postion U20 EK
    By Gong Rob in forum Pinball Technical and Repair Questions
    Last Post: 29th May 2012, 03:17 AM
  4. Ram equivalent for MPU?
    By AskJacob in forum Pinball Technical and Repair Questions
    Last Post: 11th August 2009, 08:12 AM
  5. Big Bag of Everything Equivalent?
    Last Post: 7th June 2008, 01:09 PM
