spez778 Posted January 22, 2018 Share Posted January 22, 2018 Hi guys as the title says im after a working 25 inch monitor i need for a customers cab if you have anything please let me know vic preferred cheers guys Sent from my CPH1607 using Aussie Arcade mobile app Link to comment Share on other sites More sharing options...
namastepat Posted January 22, 2018 Share Posted January 22, 2018 Just checking, are you 100% sure it's a 25 inch? That in the Aussie way of measuring tubes would be a 59cm, they were pretty uncommon in arcade machines. The more common tube size was what we called 26 inch, which is a 63cm. In the US, they called the common 26 inch tube size 25 because of the different way they measure the surface of the tube. You may already know all of this, but I am just double checking :) Link to comment Share on other sites More sharing options...
spez778 Posted January 23, 2018 Author Share Posted January 23, 2018 Hi @namastepat yep shes a 25 its in a cheap chinese knock off candy cab Sent from my CPH1607 using Aussie Arcade mobile app Link to comment Share on other sites More sharing options...
Autosteve Posted January 23, 2018 Share Posted January 23, 2018 Hi @namastepat yep shes a 25 its in a cheap chinese knock off candy cab Sent from my CPH1607 using Aussie Arcade mobile app Is it a Toshiba 25"? Link to comment Share on other sites More sharing options...
spez778 Posted January 23, 2018 Author Share Posted January 23, 2018 I'll check tonight Sent from my CPH1607 using Aussie Arcade mobile app Link to comment Share on other sites More sharing options...
spez778 Posted February 1, 2018 Author Share Posted February 1, 2018 hi all have found a replacement monitor with thanks to @dragonlee thank you to all cheers Link to comment Share on other sites More sharing options...
Super Moderator GIBO Posted February 1, 2018 Super Moderator Share Posted February 1, 2018 Just checking, are you 100% sure it's a 25 inch? That in the Aussie way of measuring tubes would be a 59cm, they were pretty uncommon in arcade machines. The more common tube size was what we called 26 inch, which is a 63cm. In the US, they called the common 26 inch tube size 25 because of the different way they measure the surface of the tube. You may already know all of this, but I am just double checking :) Not that uncommon ,some LAI Mortal Kombats,KI's,upright world Rally that style of cab had 25inch tubes Link to comment Share on other sites More sharing options...
narf_ Posted February 1, 2018 Share Posted February 1, 2018 Not that uncommon ,some LAI Mortal Kombats,KI's,upright world Rally that style of cab had 25inch tubes Got a dual res 59cm nanao here that think or looks came out of a racing cab Link to comment Share on other sites More sharing options...
