Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 54
Thread: Williams FLASH Pinball Project
  1. #21
    Nov 2014
    NSW
    438
    15 Post(s)
    104 Post(s)
    What did you use to stick the displays back on Dave?
  2. #22
    Apr 2014
    Looney Dooney 2
    1,680
    119 Post(s)
    631 Post(s)
    Quote Originally Posted by Jamie View Post
    Four inch nails, I think. Ha
    Can Play while not spilling the beer.
  3. #23
    Mar 2011
    Newcastle Australia
    6,560
    390 Post(s)
    1975 Post(s)
    Quote Originally Posted by Defender View Post
    Nine Inch Nails.
    The Artist Formally Known As #1
  4. #24
    Jul 2007
    ACT
    307
    37 Post(s)
    81 Post(s)
    Keen to see you you deal with the cupped/raised inserts. My Flash has same. Currently lots of wax on cupped and clamped down the raised arrows. Mine will never leave collection.
  5. #25
    Mar 2012
    Wollongong NSW
    1,966
    39 Post(s)
    539 Post(s)
    A little bit of progress touching up playfield
    made a few instruction book envelopes
    just need to get a better cutting blade
  6. #26
    Mar 2012
    Wollongong NSW
    1,966
    39 Post(s)
    539 Post(s)
    Replacing flipper buttons
    left side was melted
    both flipper button out old and new
    the right side one was longer
    was surprised that the right side requires a longer flipper button
    as the plywood is thicker
    left side ok
  7. #27
    Oct 2013
    NSW
    2,312
    68 Post(s)
    809 Post(s)
    Anyone got any ideas where you can get the original style flippers that have the longer shaft?
  8. #28
    Mar 2012
    Wollongong NSW
    1,966
    39 Post(s)
    539 Post(s)
    Quote Originally Posted by Cooked71 View Post
    Are you looking for part No 20-9250-5
    it is thinner at the tip
    which is more like the original ? ..
    or the thicker replacement 20-10110-5
    shaft length is 2-3/16" in length
    Not much progress except for ..
    Ken @Skybeaux has done his magic again
    returned home today to open a present
  9. #29
    Mar 2012
    Wollongong NSW
    1,966
    39 Post(s)
    539 Post(s)
  10. #30
    Dec 2016
    Barden Ridge NSW
    3,815
    194 Post(s)
    1381 Post(s)
    Originals had the bat that screwed to the base and shaft assembly. I wouldn't recommend them but I have some I can I can get measurements off.
    Just curious why you need the longer shafts?. Are you sure the flipper shaft bushings are the correct size as in not sticking above the playfield to much making it appear the flipper shafts you have aren't to short.
    Someone may have installed DMD style bushings which are longer when fitted to the playfield instead of the flipper base plate as they are intended.
