Page 1 of 12 12311 ... LastLast
Results 1 to 10 of 118
Thread: PS2 Guncon2 PCB to Original Namco Arcade Gun mod
    Nov 2008
    Sydney, AUS
    400
    9 Post(s)
    79 Post(s)
    Has anyone here by any chance modded their Namco arcade gun to work with a guncon2 for ps2?
    I would love a time crisis cab or a point blank cab, but unfortunately, I just don't have the room or can afford one at present.
    The next best thing is to mod my astro city to play ps2 namco light gun games!
    Enter my inspiration
    I'm now in the process of trying to begin this mode, but before I worry about the solenoid, first things first is to "convert" the Namco gun for the PS2 using the gcon2 pcb!
    Looking at the video, it seems pretty "easy" in terms of wiring up the +5v, GND, optical line and trigger line and the gcon2 works with the "namco" optical component without any "mods"
    Sourced out a gcon2
    Taking it apart is pretty self explanatory and I ended up with the main PCB
    Using the trusty multi meter, I found what I believe to be the trigger wire
    The GND and +5v
    And what I believe is the Optical line
    Note, I have removed the optical sensor from the PCB
    I connected the following:
    • +5v from the gcon2 pcb to the +5v line of the namco gun (goes to the optical sensor - red)
    • GND from the gcon2 pcb to the GND line of the namco gun (goes to the trigger micro switch and optical sensor - black)
    • Optical sensor line from the gcon2 pcb to the Optical sensor line of the namco gun (white)
    • Trigger line from the gcon2 to the trigger line of the namco gun (blue)
    I'm not sure if there's anything else that I've missed, but for the life of me, I can't work out why the namco gun doesn't work. The video appears to show it should work seamlessly but when I try and calibrate the Namco gun on the PS2 (gcon2 calibration screen), nothing registers.
    The PS2 definitely recognises the gcon2 and it did work prior to removing the shell and sensor.
    I'm hoping someone on here has previously done this type of mod or is very familiar with the gcon.
    Any ideas or suggestions?
    Apr 2008
    Atwell Perth
    3,280
    22 Post(s)
    261 Post(s)
    Are you using a lcd screen or a crt, I think most of these light gun games use a crt.
    Im not a wiz on these but I did read somewhere that most guns dont work on lcd's.
    Nov 2008
    Sydney, AUS
    400
    9 Post(s)
    79 Post(s)
    CRT - on my astro city
    Apr 2008
    Atwell Perth
    3,280
    22 Post(s)
    261 Post(s)
    Is the Namco gun new or tested working?
    If its a used gun are you using the wiring that came with the gun, I have had a time crisis cab that the gun would not work, ended up being 1 wire broken in the cable to the gun (Found by checking continuity).
    Have had optical sensors give up too (think I have some spares here somewhere)
    Nov 2008
    Sydney, AUS
    400
    9 Post(s)
    79 Post(s)
    It's hasn't actually been tested to be working.. I've confirmed the solenoid works and I just assumed everything else worked...
    I'll test for continuity tomorrow..
    I connect using the original 6 pin plug.. I purchased some from RS Components
    May 2017
    WA
    67
    2 Post(s)
    29 Post(s)
    It looks like you're taking your 5V and ground from elsewhere on the PCB and not where the optical sensor was originally fitted and by doing so you are missing out parts of the circuit (looks like a cap and a resistor).
    Was unable to find a guncon 2 schematic but take this guncon 1 for example
    https://leandre.hexeo.be/2015/11/18/...-103-teardown/
    Had you wired to pins 23 (+5V) and 28 (ground) you would of cut out R1 and C4.
    Identify 5v and ground for points 1 & 3 then connect up to them and retest.
    Nov 2008
    Sydney, AUS
    400
    9 Post(s)
    79 Post(s)
    I might try and locate a gcon1.
    I'm taking the +5v from the USB.
    The power line from the optical sensor appears to be 3.3v from the markings of the pcb (when I put one end of a multimeter of #3 on the sensor unit, there's continuity to the 3.3v points)
    Jan 2016
    New South Wales
    1,009
    37 Post(s)
    332 Post(s)
    Modding the guncon to have a solenoid is supposed to be easy. Could go the other way
    That and a ps2 scart mod is what I'm saying. All ps2 gun games available that way.
    Sent from my HTC 2PZF1 using Tapatalk
    Nov 2008
    Sydney, AUS
    400
    9 Post(s)
    79 Post(s)
    Quote Originally Posted by redferatu View Post
    This is my plan
    I already have all the games.. And all the parts to make it happen.
    Jan 2016
    New South Wales
    1,009
    37 Post(s)
    332 Post(s)
    Ohh OK I get what you are doing now. Probably should have tested it with the ps2 first then. Hindsight is a bitch.
    Is it worth re-installing the ps2 trigger ad-hoc and see if it tracks on the calibration screen?
