• Enraged
  • Embarrased
  • Drunk
  • Down
  • Depressed
  • Crying
  • Crazy
  • Cool
  • Cocky
  • Bemused
  • Awesome
  • Annoyed
  • Angry
  • Amused
  • Friendly
  • Geeky
  • Godly
  • Happy
  • Hateful
  • Hungry
  • Innocent
  • Meh
  • Piratey
  • Poorly
  • Sad
  • Secret
  • Shy
  • Sneaky
  • Tired
  • Wtf
  • Thanks Thanks:  0
    Likes Likes:  0
    Results 1 to 9 of 9
    Thread: Step Up Transformer?
      Berty's Avatar
      Berty is offline Ex SuperMods club
      is the arcade hermit
      Enraged
      Oct 2005
      Brisvegas
      2,570
      17 Post(s)
      53 Post(s)
      Long story short, I had a dedicated cab in which I am retrofitting new electronics which run on AU voltage but the internal wiring of the cabinet is 100-110v.
      For various reasons I don't want to add a separate 220-240v feed and would rather 'step-up' the 100-110v to 220-240v at the right point in the cab. Question is, can I use a step-down transformer to achieve this if I change the primary and secondary sides around?
      Johns-Arcade's Avatar
      Johns-Arcade is offline My quest awaits!
      is a Homepin authorised parts
      stockist
      Meh
      Apr 2006
      SE Queensland
      3,948
      183 Post(s)
      808 Post(s)
      This doesn't make sense. Are you planning to use a 240V step down transformer, then another 110V to 240V step up transformer?
      What parts require 110V (Monitor?), and what parts are you fitting that need 240V?
      Regards,
      Johns-Arcade.
      Berty's Avatar
      Enraged
      Oct 2005
      Brisvegas
      2,570
      17 Post(s)
      53 Post(s)
      Howdy - what I mean is using a standard AC step-down transformer in reverse to step-up power from an internal 100v supply. I.e feeding the 100v input into the secondary winding to achieve 220v out of the primary.
      Autosteve is offline
      This user has no status.
      Dec 2016
      Barden Ridge NSW
      2,299
      108 Post(s)
      875 Post(s)
      Quote Originally Posted by Berty View Post
      Yes you can providing the current of the old IN winding can handle the current you wish to pull out if it which is normally not the case but not always.
      I agree with @Johns-Arcade line of questions though, but the answer to your question, yes.
      stockist
      Meh
      Apr 2006
      SE Queensland
      3,948
      183 Post(s)
      808 Post(s)
      What's the game?
      Regards,
      Johns-Arcade.
      Berty's Avatar
      Enraged
      Oct 2005
      Brisvegas
      2,570
      17 Post(s)
      53 Post(s)
      So the long version of the story is this...
      I have a pair of Japanese Daytona DX cabinets. These are 100v and run off a step-down transformer. There is a 100v feed that goes to the monitor from the main cab. The rear-projection unit has now died, so I have retrofitted a ultra short throw projector into the monitor housing. I want to maintain the 4:3 screen ratio at all costs as well as the general aesthetic of the cab.
      This new projector uses 220-240v and doesn't have an option to switch the input to 100-110v. So currently I am running a second power cable out of the back of the monitor housing for the projector but I want to keep the cab as close to original as possible. (Yes, I'm choosing to do things the hard way).
      I want to get the retro-fit to look as original as possible, hence I want to step-up the 100-110v feed that is going through the Sega wiring loom to the rear projection unit to power the new projector.
      Ramakers's Avatar
      Ramakers is offline
      Dec 2012
      Belgium
      127
      10 Post(s)
      27 Post(s)
      Belgium
      Isn't it possible to feed the cabinet with 220/240 and step this down inside the cabinet where needed? If you try to step up the voltage with a transformer this is possible but but this is very won't be efficient. And you already stepping the voltage down, again loss of efficiency.
      Why do I press play to start a movie, but start to play a game?
      Holy-SNES is offline
      Sep 2012
      89
      3 Post(s)
      20 Post(s)
      Stepping the voltage up, only to step it back down is redundant.
      What exactly runs on 100v now? I'm assuming the psu? Just tap into the 240v line before the step down for the projector.
      thegrunta666's Avatar
      thegrunta666 is offline
      is building a Battle Pinball !
      Awesome
      Jun 2007
      Melbourne
      1,155
      76 Post(s)
      391 Post(s)
      Yes you can set up the transformer as a boost ( step up ) transformer. Remember that watts are watts ! What goes in will come out...so 110v 2amp in ( 220watt) will be 240v 0.9amp out . Would it not be easier to wire off the 240vac plug on the inside of the cabinet then into your projector? Ascetically, you would still have the same external connection to the cab.
