• Enraged
  • Embarrased
  • Drunk
  • Down
  • Depressed
  • Crying
  • Crazy
  • Cool
  • Cocky
  • Bemused
  • Awesome
  • Annoyed
  • Angry
  • Amused
  • Friendly
  • Geeky
  • Godly
  • Happy
  • Hateful
  • Hungry
  • Innocent
  • Meh
  • Piratey
  • Poorly
  • Sad
  • Secret
  • Shy
  • Sneaky
  • Tired
  • Wtf
  • Page 1 of 4 123 ... LastLast
    Results 1 to 10 of 33
    Thread: What is the best soldering iron temperature?
      LAP's Avatar
      LAP is offline
      is thinking pinball machines are
      like chips, one is never
      enough!
      Annoyed
      Sep 2016
      NSW
      232
      9 Post(s)
      93 Post(s)
      South Africa
      I was wondering what the best temperature to set my soldering iron or desoldering tool to ?
      Is it different for circuit board work to soldering coils ect under the playfield?
      Does it differ from make or game (possible different solder used)?
      Thanks
      LAP
      Pinball Pinot & Pizza Appreciation Society
      Frank_fjs's Avatar
      Frank_fjs is offline Geek it till it MHz
      is on PCE overdrive!
      Piratey
      Mar 2010
      Adelaide
      6,272
      25 Post(s)
      371 Post(s)
      Depends on a variety of factors.
      Soldering iron / solder /what you're working on etc.
      I don't pay attention to numbers, just set it hot enough to easily melt the solder wire. Hard to explain but you'll develop a feel for when you don't have enough heat or have too much.
      vintage's Avatar
      vintage is offline
      is missing HomePin
      Feb 2016
      1,210
      17 Post(s)
      510 Post(s)
      Yeah use a bit of judgement,PCB obviously lower so you don't cook it
      Depends on the solder grade too
      ajfclark's Avatar
      ajfclark is online now
      is probably slacking off from
      studying
      Happy
      Mar 2017
      1,297
      23 Post(s)
      460 Post(s)
      Quote Originally Posted by LAP View Post
      Yes.
      It can also differ on the same board depending on the size of the traces and the components involved.
      shedstuff is offline
      This user has no status.
      May 2010
      Ipswich
      102
      3 Post(s)
      27 Post(s)
      310F degrees for normal circuit board work with 60/40 solder.
      Dedrok's Avatar
      Dedrok is offline
      is again starting to get slightly
      Angry
      Mar 2011
      Newcastle Australia
      5,208
      240 Post(s)
      1562 Post(s)
      Under 350deg (300 - 325)for board work and for line chord or coils crank it to 450deg
      The Artist Formally Known As #1
      David_AVD's Avatar
      David_AVD is offline Nerdy & White !
      is David
      Meh
      Aug 2007
      Victoria Point (Brisbane)
      4,973
      16 Post(s)
      96 Post(s)
      I generally solder at 300°C - 375°C depending on the job.
      Use leaded solder. 60/40 is fine, but 63/37 is nicer to work with.
      "Everyone's always in favour of saving Hitler's brain. But when you put it in the body of a great white shark, ooohh! Suddenly you've gone too far!"
      Frank_fjs's Avatar
      Piratey
      Mar 2010
      Adelaide
      6,272
      25 Post(s)
      371 Post(s)
      Depends on your iron though.
      E.g. when I started out I had a cheap temp controlled iron. When the dial was at 450c the actual tip temp was only about 250c.
      Dedrok's Avatar
      Dedrok is offline
      Angry
      Mar 2011
      Newcastle Australia
      5,208
      240 Post(s)
      1562 Post(s)
      I got a goot soldering iron (not station) and has its own temperature cutoff at 325deg. So it won’t stuff up board tracks unless you really try to.
      David_AVD's Avatar
      is David
      Meh
      Aug 2007
      4,973
      16 Post(s)
      96 Post(s)
      Soldering quickly at a higher temp can be better than taking a long time to get the job done at a lower temp.
      Dry joints can also be caused by low temperature and/or lingering far too long on the joint.
      If the solder doesn't flow cleanly almost instantly as you apply heat, the temp is too low, the solder is unleaded or you're using the wrong technique.
