BIG Trev Posted March 18, 2018 Share Posted March 18, 2018 My Mac LC had a ticking power supply and wouldn't go bong [emoji852] so after watching a YouTube video I decided to recap the power supply. I also bought two spare motherboards, as the original one didn't look good, that I recapped and now it goes bong when I turn it on with either board. I'm picking up a 12" RGB monitor for it from @Kaizen late April which just needs a video cable fitted as the original was cut off. So I'll be able to see if it boots up properly then but it sounds good and the voltages are now good. The original board I removed from it is a bit crusty so I'll recap this too and maybe sell it as I don't need two spares. Another win. [emoji16] Cheers Trev. Sent from my SM-G930F using Tapatalk Link to comment Share on other sites More sharing options...
wyldcat34 Posted March 18, 2018 Share Posted March 18, 2018 My Mac LC had a ticking power supply and wouldn't go bong [emoji852] so after watching a YouTube video I decided to recap the power supply. I also bought two spare motherboards, as the original one didn't look good, that I recapped and now it goes bong when I turn it on with either board. I'm picking up a 12" RGB monitor for it from @Kaizen late April which just needs a video cable fitted as the original was cut off. So I'll be able to see if it boots up properly then but it sounds good and the voltages are now good. The original board I removed from it is a bit crusty so I'll recap this too and maybe sell it as I don't need two spares. Another win. [emoji16] Cheers Trev. Sent from my SM-G930F using Tapatalk Nice work! - I have done a few mac classics as its a common problem. Amazingly if you take the boards out and give them a damn good wash and allow them to dry out completely it generally brings them back to life. Caps still need to be replaced but its a good way to test if it still works prior to cap replacement! Link to comment Share on other sites More sharing options...
BIG Trev Posted March 18, 2018 Author Share Posted March 18, 2018 Nice work! - I have done a few mac classics as its a common problem. Amazingly if you take the boards out and give them a damn good wash and allow them to dry out completely it generally brings them back to life. Caps still need to be replaced but its a good way to test if it still works prior to cap replacement!Yeah my Mac Classic was the same. I'll remove the caps and give the original board a scrub with Isopropyl alcohol and a toothbrush before fitting the new caps. Cheers Trev. The power supply was a bit crusty too so I recapped the low voltage side. Sent from my SM-G930F using Tapatalk Link to comment Share on other sites More sharing options...
wyldcat34 Posted March 18, 2018 Share Posted March 18, 2018 Yeah my Mac Classic was the same. I'll remove the caps and give the original board a scrub with Isopropyl alcohol and a toothbrush before fitting the new caps. Cheers Trev. The power supply was a bit crusty too so I recapped the low voltage side. Sent from my SM-G930F using Tapatalk Aren't caps just the greatest! Its almost like Macs and Sega game gears are relations ;) Link to comment Share on other sites More sharing options...
