Page 1 of 2 12 LastLast
Results 1 to 10 of 18
Thread: SNES Repair
    Feb 2018
    VIC
    8
    2 Post(s)
    SNES Repair
    Hello all,
    First post on the forum! I initially joined up because im planning to build a mame box yet here I am posting about repairing an old SNES i decided to dust off and play.
    I recently tried playing my old SNES and the two games I tried had scrambled graphics. In Mortal Kombat i could see the background but not the sprited. In Mario all stars I could only see the sprite and no background. I gave both a clean with isopropyl without much luck. I also tried cleaning the SNES cartridge. I've been reading that it could be the PPU?
    I also have a Super UFO Pro 7 that isnt displaying. Not sure if its the snes or this unit. When i plug in the power adaptor it makes a short noise then stops. The floppy LED doesnt light up either.
    I've google repairers in Melbourne but havent had much luck. I'd repair it myself but my soldering skills are absolutely rubbish and given his was my first console I'd prefer not to destroy it for good! If theres anyone here who can point me in the right direction that would be great.
    Cheers,
    Trev
    Jul 2007
    Tasmania
    684
    28 Post(s)
    182 Post(s)
    Could be any number of things, but if it's been stored for a bit you may have gunk built up below the cartridge connector that'll need to be cleaned out. First up, get the system opened up, and remove all the screws from the RF shielding and on either side of the cartridge connector.
    First, check the version number in the bottom-right of the board and see what it is. If it says 1CHIP, then what I'm going to suggest won't be possible:
    If it's not a 1CHIP, take a look at the bit I've circled in red below. The top half of the cartridge connector can be removed on the non-1CHIP versions of the SNES fairly easily, so give it a bit of a wiggle & upward force and it'll pop off.
    Once you've got it off, use a toothbrush soaked in isopropyl to scrub all the pins on both sides of the connector fairly well. once you've hit all the exposed bits of the cartridge connector and it's dried, replace the top-half of it and test a game to see if it's improved any. If not, take a look at my thread on Twitter from a while back when I fixed some graphical issues being caused by corroded traces & check the areas I mention - https://twitter.com/i/moments/828409682972663808
    Good luck!
    Feb 2018
    VIC
    8
    2 Post(s)
    Great tip. Thanks alot! I can manage dismantling and reassembling more than soldering so lools like I have something to do this weekend.
    Mar 2016
    Tasmania
    73
    9 Post(s)
    19 Post(s)
    Hi poora
    How did you go with this one? From my experience a good cartridge and cartridge slot clean will do the trick but if you do discover it has corroded traces I’d be happy to help with soldering.
    Feb 2018
    VIC
    8
    2 Post(s)
    Hey Rustler. I ended up having to order the tool and havent got around to it. I hit up a retro console repairer just incase it doesn't work. I'm hoping to take it apart this week and will take some pics while im at it.
    Feb 2018
    VIC
    8
    2 Post(s)
    Quote Originally Posted by poora View Post
    Opened it up and gave the cartridge a good scrub along with a couple of cartridges but no deal.
    There's not noticeable leaks around the caps although theres a yellow substance is the corner next to the the rear inputs.
    To my untrained eyes theres also no corrosion. I've attaches some pics.
    Cheers.
    Sent from my LG-H930 using Tapatalk
    Jul 2007
    Tasmania
    684
    28 Post(s)
    182 Post(s)
    Feb 2018
    VIC
    8
    2 Post(s)
    Yep will do. Sorry, been busy setting up my mame box. I put tge snes back together will will try to take it apart this week before easter. What are you thinking with that IC?
    Jul 2007
    Tasmania
    684
    28 Post(s)
    182 Post(s)
    could be the photo, but looks like something's funky with the legs on it.
    Mar 2010
    Adelaide
    6,755
    47 Post(s)
    551 Post(s)
    You thinking fifth and sixth legs from bottom left? I spotted that too.
