Results 1 to 7 of 7
Thread: 'Pinballs Missing' Error, anyone had this?
    Apr 2013
    SYDNEY New South Wales
    936
    47 Post(s)
    274 Post(s)
    Hi all
    Have a problem with my whitewater, accidentally dropped the playfield a little hard down into the cabinet and a problem has developed where the machine thinks all the balls are missing and won't start a game. None of the three trough switches register in test, but all of the switches appear operational individually when I test with a meter and the diodes do not appear faulty. There are no wire breaks (that are visible) but this has me thinking that there is a break somewhere in the daisy-chain of these three switches. The switch for the trough kicker does work (the one that gets rid of the ball from the bottom of the playfield when you lose it) but the three sensors for the stationary balls don't.
    I'm sort of at my wit's end here, any thoughts?
    Max
    The name's Max; Bond Max
    Nov 2007
    Sydney, Australia
    9,589
    258 Post(s)
    1578 Post(s)
    Busted connector or cut wire Maxi? Check for continuity from switches up the line. A wire can be broken without the PVC being split. Multimeter on continuity (BEEP) setting is your friend.
    Dave
    Remember--The early bird catches the worm, but the second mouse gets the cheese!
    Aug 2015
    797
    55 Post(s)
    196 Post(s)
    Quote Originally Posted by maxi View Post
    Hi all
    Max
    Could be as simple as a loose plug in the trough. Check all your connections.
    Sent from my Nexus 6P using Tapatalk
    Oct 2005
    Redlands
    18,723
    146 Post(s)
    1809 Post(s)
    Do the other switches on the Row work?
    Jul 2010
    Perth, WA
    284
    5 Post(s)
    49 Post(s)
    I've had this on my WW before and had to replace an LED. Check the LED's are working in the ball trough with a camera - you can't see it with the naked eye. Check the 7 minute mark in this video:
    Oct 2005
    Redlands
    18,723
    146 Post(s)
    1809 Post(s)
    White Water doesn't use the opto trough.
    Looking at the manual those switches are on column 7, Rapids ramp main, Hot foot upper, Hot foot lower, Disaster drop main.
    I'd be checking to see if all those worked, if so you got a break somewhere.
    Jul 2009
    3,285
    182 Post(s)
    1220 Post(s)
    Grab the switch matrix diagram and study it closely to see whats being shared and start from the first switch in that Column/Row in switch edge test, as soon as the first fail appears look there that way you eliminate whether the problem lies in the row or column
