Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: Playfield Rotisserie wanted
    Aug 2017
    Nsw
    30
    11 Post(s)
    Hey guys, Iím starting a Addams gold rebuild soon and looking for a rotisserie to make life abit easier. Anyone got one they no longer want?
    Jun 2014
    QLD
    817
    71 Post(s)
    219 Post(s)
    I just did my first playfield swap. You can build your own very cheaply. Credit goes to KJS who came up with the basic idea. I just added the bike repair clamps.
    Go to Bunnings any get the Ozito miter saw stand for $59.
    https://www.bunnings.com.au/ozito-mi...stand_p6290176
    Then get 2 X 1 m X 25 cm X 25 cm square steel posts.
    You also need two of these quick release bike clamps. https://rover.ebay.com/rover/0/0/0?m...2F162192125382IMG_20171017_150251.jpg
    If you want to save money just use some brackets instead of the bike clamps but I think the bike clamps are a must item. Drill a couple of holes and get some bolts and you are done.
    Here is how it looks assembled.
    I added a sheet of old plywood as a table.
    Cheap and very practical.
    Apr 2017
    226
    32 Post(s)
    59 Post(s)
    Another shout out to KJS as l also used the ozito miter saw stands.
    Not sure if they changed but it's 30mm x 30mm for the uprights now 😉.
    Welded nuts and bolts and cut some bolt handles out of a piece of angle.
    Just used cold gal in a can and added some plastic caps on the ends.
    Worked so well l made 2.
    Sent from my SM-G935F using Aussie Arcade mobile app
    Mar 2017
    2,635
    65 Post(s)
    910 Post(s)
    I didn't use fancy bike clamps, the Ozito saw stand (though I kind of wish I had - it looks good). I made two of these:
    The uprights are:
    Saw horses: https://www.bunnings.com.au/craftrig...horse_p5710162
    2x 20mm flange https://www.bunnings.com.au/kinetic-...lange_p4700443
    2x 20mm uprights in your choice of length - I used 300mm https://www.bunnings.com.au/kinetic-...-pipe_p4700264
    2x 20mm female tee https://www.bunnings.com.au/kinetic-...d-tee_p4700089
    2x Eye bolts https://www.bunnings.com.au/zenith-7...lists%2fdetail
    The rotating bit is:
    2x 15mm flange https://www.bunnings.com.au/kinetic-...lange_p4700442
    2x 15mm 100mm pipe (should fit through the tee) https://www.bunnings.com.au/kinetic-...-pipe_p4700245
    2x 15mm end cap https://www.bunnings.com.au/kinetic-...d-cap_p4700104
    The arms that hold the playfield: https://www.bunnings.com.au/carinya-...acket_p3975785 - I used tin snips to take off one segment so the the arms are equal lengths from centre.
    2x 2x150mm clamps https://www.bunnings.com.au/irwin-15...p-set_p5861495
    There's a pair of bolts each end holding the angle bracket to the galvanised flanges and few screws through the bottom flanges into the saw horse. Most of it is only hand tight and comes apart for storage. The only slightly odd tool I needed was a tap to thread the holes the locking bolts wind in to, but I had an imperial tap and die set from fixing stuff on pinball machines already. The whole thing comes apart an folds flat for storage.
    Jun 2014
    QLD
    817
    71 Post(s)
    219 Post(s)
    That looks good too. The bicycle clamps are actually $3 cheaper than your home made set up.
    Mar 2017
    2,635
    65 Post(s)
    910 Post(s)
    Quote Originally Posted by BioBa View Post
    Possibly. I already had the irwin clamps and sawhorses though so I only really bought the gal pipe stuff for it.
    Jul 2017
    Brisbane
    390
    29 Post(s)
    117 Post(s)
    So to make your own is about $170-200. If you got an actual playfield rotisserie - how much are you looking?
    Decide how you want to live and then see what you can do to make a living WITHIN that way of life
    Aug 2009
    Shepparton Vic
    5,605
    279 Post(s)
    1789 Post(s)
    Quote Originally Posted by RaoulJuke View Post
    Around $200
    Aug 2017
    Nsw
    30
    11 Post(s)
    Whatís the length of a playfield? Just picking up some gear now
    Jun 2014
    QLD
    817
    71 Post(s)
    219 Post(s)
    Bally \ williams117 cm plus minus a couple
