Gitch Posted July 3, 2017 Share Posted July 3, 2017 So I was about to paint inside my IJ Cab, after patching, sanding, sanding, patching, sanding etc... Has anybody used black laminate inside there cab? Is there reason for and against? Link to comment Share on other sites More sharing options...
swine hoont Posted July 3, 2017 Share Posted July 3, 2017 good idea Link to comment Share on other sites More sharing options...
Gemini2544 Posted July 3, 2017 Share Posted July 3, 2017 Cost? Laminate is more expensive the Black paint. Link to comment Share on other sites More sharing options...
Boots Posted July 3, 2017 Share Posted July 3, 2017 So I was about to paint inside my IJ Cab, after patching, sanding, sanding, patching, sanding etc... Has anybody used black laminate inside there cab? Is there reason for and against? If you mean laminate as in Laminex then it will probably be too thick, the playfields often scrape the sides of the cabinet as it is Link to comment Share on other sites More sharing options...
newy16216 Posted July 3, 2017 Share Posted July 3, 2017 Would be a good idea for the base of the cab , not the sides as boots explains to thick , no room for m/ blades or art/ blades , I was just thinking about this the other day as it's a good way to cover up any holes ect , and a lot easier than replacing the base of the cab , can't see why it wouldn't work Link to comment Share on other sites More sharing options...
Gitch Posted July 3, 2017 Author Share Posted July 3, 2017 If you mean laminate as in Laminex then it will probably be too thick, the playfields often scrape the sides of the cabinet as it is Yeah that was what I meant... but yes, I didn't think of the thickness. Thanks guys Link to comment Share on other sites More sharing options...
