• Enraged
  • Embarrased
  • Drunk
  • Down
  • Depressed
  • Crying
  • Crazy
  • Cool
  • Cocky
  • Bemused
  • Awesome
  • Annoyed
  • Angry
  • Amused
  • Friendly
  • Geeky
  • Godly
  • Happy
  • Hateful
  • Hungry
  • Innocent
  • Meh
  • Piratey
  • Poorly
  • Sad
  • Secret
  • Shy
  • Sneaky
  • Tired
  • Wtf
  • Page 1 of 2 12 LastLast
    Results 1 to 10 of 11
    Thread: Karting by Rally (France) 1962
      arcadus's Avatar
      arcadus is offline Archaic Mumble****er
      is C@#tiverous
      Godly
      Dec 2006
      South Australia
      2,064
      4 Post(s)
      89 Post(s)
      Zambia
      About nine years ago I won this on Ebay from Child Amusements. I was the only bidder,
      I think it was advertised as a possible parts donor.
      Gottlieb parts do fit this, one being the faulty Game coil, a genuine Gottlieg coil-name and number inscribed.
      It came with four back legs, the front being a lot shorter.
      There is another Rally machine possibly in Victoria. The owner contacted me shortly after I bought this one requesting leg measurements as his had none.
      I sent him the spare set and made front legs from waterpipe hoping one day to find a donor 60s,70s, table for tapered legs.
      It is in very good condition being fifty five years old.
      Playfield looked repainted with the amateurish characters and handwritten cursive but looking on IDBP this seems to be normal on a few of their machines.
      Machine is poorly balanced with the steppers in the backbox and the monstrous power transformer sitting at the back of the relay board.
      It can be lifted from the front easily. My pinball trolley cannot be positioned far enough to the back to lift without tipping back.
      The unusual legs don't help.
      I did clean, adjust, etc when I first got it but it was dead on power up.
      Tracing the power from the beginning, I found one of the mains lines go through a fuse and then through the bump switches . The idea being no mains power at all when bumped.
      I replaced the crumbling AC cable and made sure the neutral was switched through the machine. If I feel inclined later I will isolate the circuit with a relay.
      The relay board where you can just see the power transformer at the back.
      The coin door with the bump switch on top of the replay button.
      The coin door hinges down, slides out and can hinge down again, a little complicated..
      I then left it for nine years.
      Pulling it out from the pile again, I retraced the AC mains again and found the relay board switch was stuck (seen centre of relay board).
      Now had power but stuck on tilt. Check all relays on relay board again and found three contacts out of adjustment.
      No tilt but not starting. Coin up worked ok, credit wheel racking up credits, found Game coil O/C. Now resetting and starting.
      Still haven't found how to score the extra ball yet.
      The extra ball feature slides the black metal plate across to block ball return and expose a kicker hole..
      Under the playfield. You can't see it clearly here but the flipper contacts are at the top. They are operated by hinged wire form in the main cabinet. I forgot to take pic...
      The backglass in excellent condition with a little verandah.
      The tilt switch using a mercury switch.
      It uses a ball shunt to push the ball up to the playfield.
      The apron is in excellent condition.
      Forgive the photo quality, I am constantly surprised how poor they are when uploaded.
      The PF glass has to be specially ordered. Standard glass is about 10mm too narrow. Maybe it's metric being French?.
      EM score motors wanted: nonworking or working
      Sega Sub Roc 3D periscope mech. needed except motors.
      Wanted, Mitsubishi 60" RP (vs 6041) complete TV gun assembly. (R Proj TV/monitors and parts taken away).
      Take Five pinball machine PCB wanted.
      wiredoug's Avatar
      wiredoug is offline
      is hiding bodies
      Drunk
      Mar 2013
      Truganina, Victoria
      7,083
      355 Post(s)
      2572 Post(s)
      cab looks very jetsons
      Gemini2544's Avatar
      Gemini2544 is offline
      is looking for a new project.
      Happy
      Mar 2010
      Wimmera, Victoria
      6,211
      95 Post(s)
      1695 Post(s)
      Adjust that Tilt plumb bob as it's touching the ring, that will be keeping the Tilt on. Nice shaped machine very retro looking.
      THE COME AND GET IT TROPHY RULES-
      Collected it, Post that you have it & hand it over to the first person that calls for it.
      vintage is offline Arcade Scrap Yard
      is missing HomePin
      Feb 2016
      1,212
      17 Post(s)
      512 Post(s)
      Quote Originally Posted by Gemini2544 View Post
      Its been overridden by mercury switch
      black ops stuff lol
      Gemini2544's Avatar
      Happy
      Mar 2010
      Wimmera, Victoria
      6,211
      95 Post(s)
      1695 Post(s)
      Quote Originally Posted by vintage View Post
      black ops stuff lol
      Still looks connected in the photo.
      arcadus's Avatar
      is C@#tiverous
      Godly
      Dec 2006
      South Australia
      2,064
      4 Post(s)
      89 Post(s)
      Zambia
      That's OK.The machine is on a trolley and the tilt switches are unplugged at the relay board.
      The flipper wire form mechanism
      There are a few of these labels.
      angs1957's Avatar
      angs1957 is offline
      is Welcome to AA! That's
      fantastic.
      Happy
      Nov 2014
      victoria
      1,403
      11 Post(s)
      247 Post(s)
      Looks like its in decent shape
      arcadus's Avatar
      is C@#tiverous
      Godly
      Dec 2006
      South Australia
      2,064
      4 Post(s)
      89 Post(s)
      Zambia
      It is in very good condition for its age..but I found some bodgyness.
      The coil mech for the plate that covers the extra ball kicker has been replaced. The big coil at the top.
      There are burn marks around the area. The bracket is homemade...
      and a switch in the middle of nowhere..
      The switch needs to be open when the plate coil is operated.
      It prevents the the VUK from continuously operating when triggered.
      (found by playing around with it).
      I can mount it on a bracket under the armature and operated by the pin to the plate..
      illawarra_steelers's Avatar
      illawarra_steelers is offline
      is planning a meet march 19
      Meh
      Jun 2006
      Bulli NSW
      8,819
      182 Post(s)
      1584 Post(s)
      there was a set of the 'tubular' legs they used on early 60's williams on ebay about 4 to 6 weeks ago that didn't sell (was watching them as i thought they would go for an insane price).
      will try to find the finished auction.
      edit: just searched and have come up empty. there has been a few sets appear over the last year, will let you know next time a set pops up
      looking to buy gottlieb electro mechanical pinball machines from any era
      Meh
      Jun 2006
      Bulli NSW
      8,819
      182 Post(s)
      1584 Post(s)
