Results 1 to 8 of 8
Thread: Combining 2x 16K ROM into 1x 32K ROM
    Dec 2006
    South Australia
    2,081
    4 Post(s)
    93 Post(s)
    New at this, so would be a basic question, hehe.
    I want to burn data from 2x 2716 (9316) into one 2732. How does the Chip Select work?.
    Does it need CS?
    Does it rely just on the memory address?.
    Nothing explanatory on the Web other than the physics of it.
    This is for an early CPU, Cinematronics.
    EM score motors wanted: nonworking or working
    Sega Sub Roc 3D periscope mech. needed except motors.
    Wanted, Mitsubishi 60" RP (vs 6041) complete TV gun assembly. (R Proj TV/monitors and parts taken away).
    Take Five pinball machine PCB wanted.
    Jun 2006
    Central coast / Newcastle
    1,416
    258 Post(s)
    147 Post(s)
    I'm not sure what type of programmer you are using but with mine i just select the chip as a2732 ,then load the first file onto the buffer , then set the buffer to a positive offset of 800(that's where the first file finishes) and then load the second file.
    Then burn the image onto a 2732
    Hope that helps
    Dec 2006
    South Australia
    2,081
    4 Post(s)
    93 Post(s)
    How does the game CPU differentiate between the two files on the 2732?. I thought that CS selected a particular ROM. Since the data is on one ROM now and not two.
    Jun 2006
    1,416
    258 Post(s)
    147 Post(s)
    I'm only familiar with pinball boards but you always have to change board jumpers to accommodate the different rom sizes so the cpu knows where to select the data
    Dec 2006
    South Australia
    2,081
    4 Post(s)
    93 Post(s)
    Oh ok, I understand now. Thanks Ken, much appreciated.
    I have just found that there are no jumpers but there are modifications to traces etc. to achieve this.
    Feb 2010
    ACT
    723
    27 Post(s)
    182 Post(s)
    The highest address line (so A11 for the 2732) would switch the two halves of the ROM in this situation.
    Jul 2009
    SA
    2,843
    90 Post(s)
    815 Post(s)
    Quote Originally Posted by Skybeaux View Post
    Hope that helps
    The same can be done with cmd prompt
    type rom1.rom>>newrom.rom
    type rom2.rom>>newrom.rom
    the result is the first rom added to a new rom file, then the second rom appended to the newly created rom
    Oct 2005
    Redlands
    19,115
    158 Post(s)
    1936 Post(s)
    or just download HxD(best free hex editor by far) and use the "Concatenate Files" options under Extra then File Tools.
