- 0
Need your knowledge on donor compatibility
Recently Browsing 0 members
scrappy
Hi . I have a mame 2000 plus games on it. I aquired this cabinet about a month ago . it came with a wg 25 inch zenith crt. The crt has 6 of the 8 neck pins missing off it due to the prior owners rampage .. So i hear the tube is pretty much toast i understand. A couple days ago i ran upon a wg 25 inch phillips with pcb and neckboard. The only diifferance i can tell from the old zennith and my new find the phillips is the phillips is ten pin. What are the chances i can use the phillips with its pcb and neckboard as a donor . what are the chances i can just swap them out and it will simply work. .. my other question is if the original pcb with the zennith will work good with the phillips crt . Im not sure how the pcb that came with the phillips will petform. But i was told that the phillps crt does work. . Is there any place where i can find info for compatability for these crts etc.... thanks guys for all your help ... and remember to try not to beat up on the newbie to much .... thsnks. I am icludeing some pics of old crt info and new phillips info. .... looking forward to all your help. Thanks again.
Now the original zenith with broken pins
[ATTACH]108303[/ATTACH]
Sent from my SGH-I747M using Aussie Arcade mobile app
10 answers to this question
