Centigrade 37 Advance Lanes Problem
riverinapinball
19 answers to this question
so none of the lights in the lane light? if that is the case you have a break in the line for the lights.
Yep no lights . I did some basic metering. Appeared to be no break. But will check again.
Would seriously suggest getting the schematic - you'll be, literally, in the dark without it...
The only schematic I have seen for sale is in the US.
So I might order one soon if I can't source one locally.
I have removed all globes except 2. , and found one was light slightly .
When I measured the voltage was 2.1 vac
I must have a short or bad connection on the power line . Still searching.
Schematic is weeks away..
Ok , I found the alternating lane lights controlled by replay "A" located under the playfield.
The "White" coloured wire on the switch doesn't have any power on it. I can't see we're it comes from?
For testing purposes a used a jumper wire to supply power to the "white" wire on the as per picture. It's jumped from the Gi lights.
Now it is working with the jumper wire attached!
