Page 46 of 66 FirstFirst ... 36444546474856 ... LastLast
Results 451 to 460 of 651
Thread: What pins have been coming thru the Dedshed
  1. #451
    Nov 2013
    Brisbane, QLD
    108
    41 Post(s)
    22 Post(s)
    I like the coloured posts
  2. #452
    Mar 2011
    Newcastle Australia
    6,573
    391 Post(s)
    1977 Post(s)
    Attacking the top flipper assy.
    These are always neglected. Why buy a 2nd Flipper kit when you can buy 1.
    Strip and clean off all the gunk.
    Polish with Autosol
    Straighten bend stop bkt
    Install new bush
    Install new flipper pawl
    (plunger/link Ok)
    Cut off bad spring ends and renew
    Change to correct Coil stop.
    Clean bat and install
    Thatís one done.
    Bent end stop
    Bent bkt fixed
    New parts
    Installed
    The Artist Formally Known As #1
  3. #453
    Mar 2011
    Newcastle Australia
    6,573
    391 Post(s)
    1977 Post(s)
    And Thing Flip is done.
    As I installed it, I noticed a small crack in the bush under double magnification.
    So need to order more. Am out of stock.
    Also the outhole kicker assy is done.
  4. #454
    Mar 2011
    Newcastle Australia
    6,573
    391 Post(s)
    1977 Post(s)
    Lower flipper assyís done and installed. Just need new bump stop rubbers, correct coils and EOS.
    Flipper bat cleaning is a must to get rid off the rubber residue.
    Donít forget the trough metal polish, especially the rough, filthy ball gate.
  5. #455
    Mar 2011
    Newcastle Australia
    6,573
    391 Post(s)
    1977 Post(s)
    Last of the stuff from the old playfield.
    Posts, mini posts, inlane rails and outlane post hardware.
    Cleaned, polished in the drill and fitted.
    Thatís all for fitting to the top now.
    Next up is reflow all the lamp board solder and pins. Noticed some cracked ones but re do them regardless.
    Firstly the 2 already installed, then time to clean, install the harness, and finish remaining boards before fitting.
  6. #456
    Nov 2013
    Brisbane, QLD
    108
    41 Post(s)
    22 Post(s)
    Edy your work is so meticulous, it's wonderful.
    And @Turbo27 will be pleased, the bumper caps are now in their correct positions! Yoohoo!
  7. #457
    Mar 2011
    Newcastle Australia
    6,573
    391 Post(s)
    1977 Post(s)
    Quote Originally Posted by roland rat View Post
    Yes, best time to do it is when completely pulled down.
    Need to put together a parts order this week.
    Cleaning the harness will be fun.
    But will look and play like, or better, than new.
    Will ring you on the weekend.
  8. #458
    Mar 2011
    Newcastle Australia
    6,573
    391 Post(s)
    1977 Post(s)
    Ugh.
    This.
    Dumped roughly in place.
    Picked through, untangled and re run a few bits, roughly lined up where everything goes.
    Now to pick through and install bit by bit.
  9. #459
    Dec 2016
    Barden Ridge NSW
    3,829
    194 Post(s)
    1386 Post(s)
    Do the new playfields have the cable clamp holes marked?
  10. #460
    Mar 2011
    Newcastle Australia
    6,573
    391 Post(s)
    1977 Post(s)
    Quote Originally Posted by Autosteve View Post
    Yup.
    Everything has a tiny location dimple. And I mean tiny.
