What pins have been coming thru the Dedshed
Ok.
Polished the plunger ramp.
Stripped/ cleaned the out hole kicker and left drain kicker, new sleeves.
Cleaned polished all the under apron gunk.
Removed all the trough metal and stuck into the vinegar soak
Clean metal and resolder switches on top ramp switch bracket.
It is coming up really nice considering the condition it was in at the start
Sent from my C6903 using Tapatalk
Yeah.
Seeing the results is finally starting to look great.
Next is to make play great and see if it boots up. As it was non working when I got it.
If I owned it, I would have clear coated the playfield. But that’s another major expense that won’t be done here.
Added some new flasher sockets
Cleaned/ polished trough parts after de rust soak.
Polished apron and fitted
Straighten the playfield prop guides.
Straightened left, bent right. They were badly bent and back to front.
I'm looking forward to the Cleopatra restore. :049:
First one is just swapped everything over to make the best out of 2, then get up running.
It’s actually almost done.
2nd one will need new parts and maybe a pf clear coat. And new boards.
A classic example of a rubbish idea.
These things started bending virtually as soon as someone "that wasn't trained exactly how to use them", tried to lift a playfield.
I'd hate to think how much time I spent straightening these things on site.
Such a shit idea and anyone doubting how bad, without instructing a person ask them to lift up the playfield and just watch how much damage they can do and how quickly.
If your lucky they will just stretch the springs. If you are unlucky they will bend them to the point they scratch the shit out of the inside of the cabinet when they bend, not hook on the pivot bolts and again if your lucky jam the playfield in the vertical position or if your unlucky, neither hook will catch and the playfield will drop vertically straight down onto the bottom of the cabinet.
I have seem everything that can possibly go wrong with these things believe me.
Yep.
And the pointy bits were at the back.
No springs.
But they were the least of the problems.
I want to see a Charlies angels restore happening there at some stage? Now that’s a classic. Ha
We will chat when I’m down next. Maybe next year it can fit in.
Home stretch
Tidy up and fix wiring , much better.
Clean out cab and add missing earth braid.
Install missing headbox latch
Install playfield and some glass.... ready to be wired in
Nice work. I was worried till I saw the next picture with heat shrink on the cable repairs. ;)
Been laminating the operator's machines inner cab "matrix maps" and head "fuse data sheets" myself.
Being laminated allows for a quick wipe down in future but I also use drawing pins to hold them in place rather than staples so when they come back here for repairs, I can easily pull the drawing pins out and read them as a piece of paper in my hand rather than having to lift up or pull playfields out of the way to read them.
Easy to replace by lining up the drawing pin holes and reinserting the drawing pins.
Also looks pretty sharp.:)
Well.
Wiring is done and is booting up.
Just need to find the dmd ribbon cable then test everything.
Need to
Replace rear glass channel
Check coin door interface wiring
Install plunger
Install new topper dome and leds.
