slampt Posted September 12, 2016 Share Posted September 12, 2016 Hey Folks, This is a shout out to anyone in Perth who might have a JAMMA connector. Turns out the stock one in the Sega Blast city is a little loose. I connected it to a CPS1 board and didn't check before turning it on, unfortunately due to not checking (I usually do) I let the smoke out (pink smoke). Upon inspection the connector is a little loose and my spare ones I bought from QLD are a little too small. So does anyone in perth have a spare connector or 2 I could purchase so I can repair my harness and hopefully test my CPS1 board (I hope I didn't cook that too!) TIA Slampt Link to comment Share on other sites More sharing options...
ssilla Posted September 19, 2016 Share Posted September 19, 2016 Hi Slampt, Mikes Arcade sells Solder and Crimp Type Jamma 56-pin edge connectors. See Link: https://www.mikesarcade.com/cgi-bin/store.pl?action=search&category=Connectors If you need one right away send me a PM and I'll help you out. I would also recommend checking the Power rails are within spec. Link to comment Share on other sites More sharing options...
