Apple IIGS Rom 01 Repair
Took a punt on a "untested" Apple IIGS machine off ebay a few weeks back and of course it was dead. I've always wanted to play around with vintage Apple II's which I remember we had at primary school. I have no interest in Mac's.
I really don't like how they name the boards based on the rom revision. Rom 00 and 01 are pretty much the same with 256k built in with a 1 meg rom. Rom 03 is a decent upgrade with 1 Meg on board and has 2 x 1 meg rom slots and is suppose to be 10% faster.
I missed out on the Apple RGB monitor so I made a IIGS to Commodore 1804s cable which works nice.
Symptom: Dead
Fix: The GS uses a 65C816 which is a 16/8 bit hybrid of the 6502, kind of like the 8088 used in early IBM's and Clones.
First I checked both the reset and clock which were fine, looking at the Data lines 2 were completely dead.
Sadly I had no spare CPU's but so I ordered several from China which still haven't arrived. Luckily The French fellow I bought a Rom 03 board from threw one in for me and it arrived last week. Replacing the CPU the machine sprang to life.
Do some reading about the machine it has a built in diagnostics which is nice. To access the diagnostics you hold down Apple open and Option on power up (I didn't even know what apple open was)
Running the diagnostics I got this error which in the error list I found on the web means Ram data error as per below.
Sound Test:3
AA= 0C
DD= 01: RAM data error
02: RAM address error
03: Data register failed
04: Control register failed
05: Oscillator interrupt timeout
Ram used is 4464, I pinched one off a spare Turbo XT Motherboard and tried piggy backing on top.
Ran test again and :)
More Apple IIGS repair logs to come including my Rom 03 board with battery corrosion damage, 3 disk drives I repaired and a Apple IIc 9" green screen monitor I'm currently working on.
