Adding External Subwoofer - the easy way
3. Twilight Zone - Another great one. When you defeat the "Power" the knocks sound awesome.
Wait until you hear the intro to LITZ!! http://newboards.theonering.net/forum/gforum/perl/gforum.cgi?do=post_attachment;postatt_id=15159;guest=173353713&t=search_enginehttp://www.animated-smileys.com/emoticons/animated-smileys-weapons-016.gifhttp://newboards.theonering.net/forum/gforum/perl/gforum.cgi?do=post_attachment;postatt_id=15159;guest=173353713&t=search_enginehttp://www.animated-smileys.com/emoticons/animated-smileys-weapons-016.gifhttp://newboards.theonering.net/forum/gforum/perl/gforum.cgi?do=post_attachment;postatt_id=15159;guest=173353713&t=search_enginehttp://www.animated-smileys.com/emoticons/animated-smileys-weapons-016.gifhttp://newboards.theonering.net/forum/gforum/perl/gforum.cgi?do=post_attachment;postatt_id=15159;guest=173353713&t=search_enginehttp://www.animated-smileys.com/emoticons/animated-smileys-weapons-016.gifhttp://newboards.theonering.net/forum/gforum/perl/gforum.cgi?do=post_attachment;postatt_id=15159;guest=173353713&t=search_engine
Well Travis @saber007 I finally got around to hooking up the sub to STLE and TRON. Checked the ground and got .001 but if I join the probes together direct I get .001 so all good. Tron has a good improvement and you can hear base line so much better. Now to try STLE. I see what you mean there seems a continuous base line there. Big improvement for the dollars invested. As you say we are not listening to HD quality here. Thanks for all the extra info regarding the possibilities of frying something. Cheers everyone now let's play some pinball. Edited by JOKERPOKER
  • 1 year later...
@JOKERPOKER @saber007
Bump. So some time has past any updates good bad or otherwise on this sub?
I love it Lucas. Bang for buck is the key here. I have had no trouble with it running 2 machines at the same time with no crossover. Currently on STLE and GOTLE
It's not as good as some i have heard but it's nowhere near the price of others either.
Sorry about the late entry to this thread but (being Dandenong based) I've had 11 of these Active Subs in my collection running 2 machines a pop for well over a year and a half now and they are AMAZING.
So good in fact i'm thinking about getting some t-shirts done ... EAT, BUY PIN, INSTALL COLORDMD, PLUG INTO EXT.SUB, SLEEP, REPEAT....
I like the last bit Scott. You are such a pinball tragic like us all :lolI would like to see a drink section as well. It's my Friday afternoon sitting in the big comfy chair with a bourbon and coke just looking at them. Ain't that right @Railways ;)
Bang for buck they are not bad. But I just found they haven’t given as much punch as I would have liked. But for $100 bucks or $50 per machine it is better then the built in one, that is for sure.
But maybe I am too picky.
Plus I also had an old sub from my media room that I wasn’t using and it sounds amazing... But it is probably not a fair comparison as it was a $1000 when new.
Sent from my iPad using Tapatalk
Yep way better than a cheap internal sub. Again bang for buck. Switch it off half way through a game and you really miss it. The battering ram on GOTLE just isn't the same without it.
Does the original subwoofer have polarity? I can't find doco to tell me what is + and what is -.
It does. Polarity should be marked on the speaker terminals. Not always boldly, but there will be something.
It's taken me months but I've finally found my old sub woofer buried under the house and got it all wired up to a couple of machines - what a difference a sub makes!
Very happy with the result and thanks to all for the thread and advice contained within.
