Welcome Welcome:  0
Results 1 to 1 of 1
Thread: RaspberryJAMMA - up to date information
    Jun 2013
    VIC
    731
    77 Post(s)
    346 Post(s)
    www.arpicade.com
    I'm going to try and keep all the latest info here in one simple post to save people the hassle of trawling through the huge thread for info.
    ### HARDWARE INFO ###
    RaspberryJAMMA is a Raspberry Pi JAMMA adaptor that converts a RPi into a true JAMMA board, intended for you to do whatever it is you want with it with no hardware lag and scanline accurate low res output. No modification to your JAMMA cab is required (unless you want to add a kick harness). It can be configured for normal JAMMA (w/ optional kick harness) or for 6 buttons on JAMMA via dipswitches. Video out is RGBS on JAMMA or can be reconfigured to output higher resolutions through VGA. The board features amplified mono sound or line level stereo can be used (only one at a time, although a splitter may work...).
    RaspberryJAMMA v3 is available now, PM me for sales.
    My current prices (in Aussie dollars) are: $145 without a Pi, or $215 with a Raspberry Pi 3 and 16gig sd card included. If you want a larger SD card PM for more details, if you already have an SD card the software is free to download. As a guide economy air mail costs: Australia (Express Post)/NZ $10, North America $15, Europe $20, anywhere else PM me for a quote. Add $8 for air mail with tracking.
    Now also available through www.highscoresaves.com if you're in North America this is probably the easiest way to get a RaspberryJAMMA.
    ### SOFTWARE INFO ###
    ARpiCADE 3.84: https://arpicade.com/forums/viewtopic.php?f=12&t=1062
    ARpiCADE 3.83: https://arpicade.com/forums/viewtopic.php?f=12&t=766
    ARpiCADE 3.811 (full image with fixups applied).
    https://mega.nz/#!MzAFFQpS!_6saSpOYN...87fC9btAUOaUnQ
    ARpiCADE 3.8 (full image release, 4.35GB download extracts to make an 8 gig SD card image) (more info in post 1491 page 150 of the stupid big thread https://www.aussiearcade.com/showthr...86#post1144886 )
    https://mega.nz/#!VyBjXBbY!bxEBtrsxz...hRN0u95GM0fJmo
    advmame config files fixup for 3.8:
    https://drive.google.com/open?id=16q...65602tMkjdrukS
    just unzip and copy the contents to /boot/config-updater (you need both the update.sh script and the folder 3.811_fixupdate with all it's contents). The update can then be installed through the update option of the service menu.
    ARpiCADE 3.72 update (requires 3.71 sd card) available from arpicade.com (this uses a different hotkey system to previous releases as well as a new version of Attract-Mode with the keyboard bug fixed & a new audio bug...).
    ARpiCADE 3.71 update (requires a 3.7 SD card to update) (info here: http://www.aussiearcade.com/showthre...rry-PI/page138 post #1378 )
    https://drive.google.com/open?id=0B6...jF0QkFCZjhUMFE
    ARpiCADE 3.7 (10 part download)
    https://drive.google.com/open?id=0B6...jFoZlp0S1dDWUk
    https://drive.google.com/open?id=0B6...EZMd0RINmh3NlE
    https://drive.google.com/open?id=0B6...ExqeGF0RTZLMm8
    https://drive.google.com/open?id=0B6...zNzMnpyR3ktbGc
    https://drive.google.com/open?id=0B6...kwwdG8zYTZWT00
    https://drive.google.com/open?id=0B6...0pXUVFZcWREN1k
    https://drive.google.com/open?id=0B6...mZrNmE5RG9KTHM
    https://drive.google.com/open?id=0B6...0F0OHNpeXAybE0
    https://drive.google.com/open?id=0B6...EtjVUg3RnE5V3M
    https://drive.google.com/open?id=0B6...VJ4M1BXeWJWaGc
    ARpiCADE 3.7 INSTRUCTIONS:
    https://drive.google.com/open?id=1ec...zc2Q343KVqJueg
    v3.6 (info page 87 of the big thread)
    http://www.mediafire.com/file/txum3x...piCADE_3.6.img
    (smaller download compressed version - thanks Cathal
    https://mega.nz/#!kVoUVCpC!CRcwCi8SO...p_uKf5LSf8RMys
    3.6 instructions (the ones included on the image are outdated):
    https://drive.google.com/open?id=0B6...U5PS1JHUjc5VTA
    ARpiCADE 3.6 config sets:
    low res vertical:
    https://drive.google.com/open?id=0B6...lpIRkJOS3I3bXc
    high res horizontal:
    https://drive.google.com/open?id=0B6...UNGYnhPV3psd2M
    V3.5 software links page 66 of the big thread (16 part download). Single links below:
    https://dl.dropboxusercontent.com/u/.../ARpiCADE35.7z --- thanks to thegleek for the re-up --- link currently down
    https://mega.nz/#!VMowmJKb!XnNRZhsV7...M_HzZbNa9Ew3Tw --- thanks Cathal
    http://www.arcadecrusade.com/downloads/ARpiCADE35.7z --- thanks Mattroid
    3.5 CONFIG SETS & MAME0172 (with the patches by MKCHAMP and Ozfalcon), the mame172 folder goes in /home/pi
    https://drive.google.com/open?id=0B6...3ppci1yMnNEZ1U
    OLDER ARpiCADE V3.1 software (pi2 and pi3)
    http://tinyurl.com/h337jtf -- thanks to Jed for single file version
    EXTRA SETUP FILES for v3.1:
    https://drive.google.com/open?id=0B6...jRhaUNraVEycXc
    Current instructions are included in the image.
    Older v3.1 software instructions can be found here: https://drive.google.com/open?id=1Iq...s2bpBaOq5SDUSA
    Retropie 4.0.2 for RaspberryJAMMA:
    (it's in three parts and will need to be resized once you have it on the sd card so there's usable space. Other than adding the joystick driver and setting it to 480i it's vanilla Retropie and will require all the standard sort of Retropie stuff. I have no intention of supporting this image, I do not use it, if help is needed with it check out the Retropie site/forums (unless it directly has to do with the RaspberryJAMMA hardware).)
    https://drive.google.com/open?id=0B6...nRwQjNxRlZ5YjA
    https://drive.google.com/open?id=0B6...1l2VDVzY1BSdjQ
    https://drive.google.com/open?id=0B6...i1yZEdxTUZwN0k
    RaspberryJAMMA V3 board layout: https://drive.google.com/open?id=0B6...0M0Ti1idTI1cHc
    How to mount pi to board: https://drive.google.com/open?id=0B6...0lxblBUbmlJdTQ
    Guide to V3 dipswitches: https://drive.google.com/open?id=0B6...zV6QjVxSVZQbmc
    Which emulator for which rom spreadsheet WIP: https://drive.google.com/open?id=1mg...ojXRw1yf9GdWoY
    VIDEO OF SOFTWARE (running vertical, not uploaded by me, thanks):
    If you want to try and make any other RPi images RapberryJAMMA friendly the GPIO control module for the JAMMA adaptor can be downloaded here:
    https://drive.google.com/open?id=0B6...nV2ckc1VDZLSHM
    it needs to go into /usr/src (on Raspbian, it may vary for other builds) and be built and installed using DKMS, check out https://github.com/recalbox/mk_arcade_joystick_rpi for more details as it is this driver with a slightly different config.
