80s KiD Posted August 25, 2015 Share Posted August 25, 2015 Hey guys, I posted my M.A.M.E conversion cab here: http://www.aussiearcade.com/showthread.php/75527-Original-1990-s-Gottlieb-Challenger-20-quot-Upright-Hybrid-Arcade-Machine I currently have the machine listed on eBay, and would like to see it going to a new home without any worry of future problems occurring. I have been "testing" the machine for the past week or so, and have begun to notice that the J-PAC loses sync. This will occur approx.. 10% of the time. To fix the problem, you simply unplug the J-PAC from the USB port and plug it back in again, and all is well. I don't want to have to explain to the potential buyer that it's a requirement every time the J-PAC loses it's sync. The funny thing is though, the sync lights on the J-PAC are fine. So I did a bit of research and discovered that quite a number of people are having the same issue. Particularly those who have purchased the newer model J-PAC (like myself) and also, those that connect the J-PAC to their PC via a PS/2 to USB cable. Here are my findings: http://forum.arcadecontrols.com/index.php?topic=142001.0 http://forum.arcadecontrols.com/index.php?topic=134130.0 Apparently it has to do with the J-PAC not receiving enough power via the USB port to supply the on-board video amp. So it will simply cut out/lose sync. I didn't really find a definitive solution other than to try an older J-PAC or to try using a PS/2 cable (which I will do today). I just wanted to know if anyone here on AA has experienced a similar problem, and whether or not they found a solution. Cheers, Dylan Link to comment Share on other sites More sharing options...
namastepat Posted August 25, 2015 Share Posted August 25, 2015 I actually have this problem on one of my cabinets where it is powered by PS/2. So I can rule out the USB side of things being the only cause. I just reboot the PC and it's fine. Mine wouldn't happen 10% of the time though, maybe more like 2%-3%, it's a rare occurrence for me. Link to comment Share on other sites More sharing options...
80s KiD Posted August 25, 2015 Author Share Posted August 25, 2015 I actually have this problem on one of my cabinets where it is powered by PS/2. So I can rule out the USB side of things being the only cause. I just reboot the PC and it's fine. Mine wouldn't happen 10% of the time though, maybe more like 2%-3%, it's a rare occurrence for me. Wow, so strange?? A few people reported that switching to a PS/2 cable did solve the problem, but not in all cases. I might give it a go, is there any difference in using a PS/2 as opposed to a USB cable in terms of latency with the inputs etc.? Some people have said that using a PS/2 connection is a little slower than USB. Link to comment Share on other sites More sharing options...
namastepat Posted August 25, 2015 Share Posted August 25, 2015 There is apparently no difference and it REALLY pisses Andy from Ultimarc off that people think there is a difference :) That's one of the reasons why he killed PS/2 on the latest version, as he vehemently states that USB is identical in every way. Also, I always heard the OTHER way around, that USB had input lag as opposed to PS/2 having no input lag. This is what Andy has done his best to dispel. Link to comment Share on other sites More sharing options...
SE1Z Posted August 25, 2015 Share Posted August 25, 2015 Does it have no sync on startup, or after playing for a while? I assume it's only a problem for ppl running an arcade monitor? Link to comment Share on other sites More sharing options...
80s KiD Posted August 25, 2015 Author Share Posted August 25, 2015 Does it have no sync on startup, or after playing for a while? I assume it's only a problem for ppl running an arcade monitor? It can occur randomly, usually only during play. Not through Windows startup/BIOS screens. As mentioned, the "sync in" and "sync ok" lights are both on. It is connected to a NANAO KZ20 20" CRT. I tried a PS/2 cable, so far so good. But it could be a week before I see a problem, who knows... Perhaps the problem only occurs on some graphics cards, then again.. It could be related to the actual PC. Too many to list, most have narrowed down to a power loss via the USB port. Link to comment Share on other sites More sharing options...
namastepat Posted August 25, 2015 Share Posted August 25, 2015 I just live with it on mine. It happens so rarely that it doesn't bother me enough to fix it. I know it's not only USB related though, as I do not use USB on any of my J-PACS. Link to comment Share on other sites More sharing options...
Diverdown Posted August 19, 2016 Share Posted August 19, 2016 Mine was doing this only yesterday for the first time in several years. I "fixed it" by reordering the USB ports i was using for all the controllers. Try this and also try to connect it to the PC using a "powered" USB port or hub. Dunno - it just worked for me. Link to comment Share on other sites More sharing options...
