nogi Posted March 3, 2015 Share Posted March 3, 2015 Hello all, I?m from Brisbane and usually busy running my shrimp keepers forum to do anything else. But a guy here at work got me hooked on the DIY arcade scene so here I am. I?ve got a Raspberry Pi2 on order along with a bunch of other components. My plan is to make a retro style desktop arcade for my 2 boys so please bear with me as I?ll have a ton of newbie questions along the way. cheers, NoGi Link to comment Share on other sites More sharing options...
felixthadog Posted March 3, 2015 Share Posted March 3, 2015 Welcome to Aussie Arcade, you've come to the right place :D Cheers, Matthew Link to comment Share on other sites More sharing options...
nogi Posted March 3, 2015 Author Share Posted March 3, 2015 http://tapatalk.imageshack.com/v2/15/03/02/fe34dcc195224e7cfa3a4f642cbf1a22.jpg Stuff slowly arriving Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
angs1957 Posted March 4, 2015 Share Posted March 4, 2015 Hi & :welcome: to AA Link to comment Share on other sites More sharing options...
Kaizen Posted March 7, 2015 Share Posted March 7, 2015 (edited) Hi Nogi, welcome to the forum, I remember you from SKF. I got some Yellows off you a while back. Plenty of good info and advice here. :welcome: Edited March 10, 2015 by Kaizen Link to comment Share on other sites More sharing options...
micky Posted March 16, 2015 Share Posted March 16, 2015 Welcome. You should be able to find any info you need. :welcome: Link to comment Share on other sites More sharing options...
raziel2001au Posted April 19, 2015 Share Posted April 19, 2015 From Brisbane here as well... how's your build coming along? Just a heads up, some joysticks, like the Sanwa JLF joysticks are designed to be mounted very close to the surface - in Jap cabs they are normally mounted on a metal plate (they recommend mounting no thicker than 5mm). So if you're going for those, you may be best off mounting on perspex (with artwork below it), or doing wood in multiple layers if you're not intending to route out areas to make space for the mounting plate. Link to comment Share on other sites More sharing options...
senneitts Posted April 25, 2015 Share Posted April 25, 2015 Welcome aboard and good luck with your project! Link to comment Share on other sites More sharing options...
