- 0
Broken 25pin IDC 0.100" connector
Recently Browsing 0 members
Jesder
I decided to remove the solenoid driver board from my Fireball tonight to investigate an issue with the return gate.
I noticed something odd about the J3 connector - to be specific, 1 wire missing from the connector but connected directly to the pin.
I removed the connector and found that the connector itself was broken in two. Where it had broken, that wire was now soldered directly to the pin. This pin is for one of the mushroom bumpers, so isn't related to the gate, but I'm keen to fix this connector anyway. On a closer look at that broken section it was black on one side, so possibly it had burnt hot at some point in the past before being hacked into a working state again?
http://www.enteryourinitials.com/images/fireball/fireball_broken_idc.jpg
It's an IDC type. 25 pin and 0.100" gauge.
A quick search has turned up no results for a 25 pin IDC. In fact I could only find 0.156" connectors (but none in that length).
Any ideas on where to source a 25pin 0.100" IDC?
8 answers to this question
