PCB or MAME
Ok this is been maybe asked a million times but seeing i don't use mame or have a mame setup anymore is it possible i can play in the league using original hardware? Only issues i see is for example Shinobi i have a different set Sega 16B board to the one named which is a Sega 16A but its the same as the 16A version
Cheers
Edit read in rules you can use original pcb but with shinobi even though its a original pcb just not a 16A version can i still be apart of it?
Yes it's OK to use your PCB for Shinobi, you are welcome to join the MGL to play and have fun ... :)
