Urgent help needed broken Stern pinball coil
Ok straight to the point I damaged my top eject coil on ACDC and found the wire coil to be damaged.
The wire has snapped in the wound area is there a quick temporary fix for this ?? Can I rejoin the wire somehow it has started to unravel a bit.
Need the game for a meet tomorrow :(
How far from the solder lug has it broke?
If it is only a small amount then just re-solder the new end to the lug, if you are unsure check the resistance against another coil.
I went ahead and did this before I checked back here , had nothing to lose and working!! Played it for a couple of hours and no issues.
Just hope it holds up tonight.
How many turns are damaged?
Damaged as in the clear coating has come off?
Got a photo of it?
Yes the very outside wire snapped only once thankfully , unraveled a little bit, tinned the end and solder it back together I kept it a few millimetres off the remaining coil.
Should be OK as this coil does not get used as much as others I am hoping. :)
