Looked at a T2 today that was working fine, then the plunger coil locked on, blowing Q58 as well as the associated fuse. So i took the power driver board home, replaced Q58 (TIP102), plus its 5401 predriver, as well as the diode.
I put the repaired power driver board in a Dr Who at home, and it worked fine, with all coils firing and no lock ons.
So this morning i took it back to old mates place, put the repaired PD board back in, started a game and the transistor was blew straight away.....
So then i looked at the coil itself - resistance was around 3.5 ohms, so prob OK. I then got the kickback coil (same one - i think its 23-800), and put it in the plunger, put another diode, TIP102,5401 in PD board, and same problem again.
Any ideas - its obviously not the coil, the coil lugs are clear of any earthable objects, so i'm leaning towards a wiring short - although seems very unlikely as it happened out of the blue when the bloke powered the machine on. Power driver board problem seems unlikely as i thought i would have picked it up in Dr Who?
robm
Any ideas on what more or how to test?
Thanks
Rob
5 answers to this question
