namastepat Posted May 14, 2013 Share Posted May 14, 2013 Hey guys, Been fiddling with my RGB pots on my MAME machine and I just can't quite get it right. Does anyone know of a good game I can put into service to get a screen like this? Looking for one with the crosshatch and the trasitional colour bars. http://wiki.arcadeotaku.com/w/How_to_Correctly_Set_Up_Monitor_Colours_and_Brightness Also, this site mentions RGB cutoffs and gains, which I am not sure about. I have a Kortek KT-2603X chassis. There are colour pots on the chassis, and then colour pots on the neckboard. I am assuming one is the gain and one is the cutoff? Or is that totally wrong? :) Thanks for the help! Everytime I adjust the screen I get it to a good point, but then I am not fully happy with it, and I adjust it again and usually make it a bit worse :) Link to comment Share on other sites More sharing options...
Gemini2544 Posted May 15, 2013 Share Posted May 15, 2013 Just use a grey screen. Any wrong colour will be obvious. Link to comment Share on other sites More sharing options...
casperthefriendly Posted May 15, 2013 Share Posted May 15, 2013 Neo games have quite a good colour test in the service menu. I won't pretend to fully understand it, but this works for me; Pick the solid screens of colour in the tests and tweak the gains until all the colours look ok (check white as well( Then move onto the graded bands of colour that fade into black - tweak the cutoffs until the colours fade to black at the same point Rinse and repeat until you're happy - you'll also probably need to tweak brightness and contrast too... HTH Hey guys, Been fiddling with my RGB pots on my MAME machine and I just can't quite get it right. Does anyone know of a good game I can put into service to get a screen like this? Looking for one with the crosshatch and the trasitional colour bars. http://wiki.arcadeotaku.com/w/How_to_Correctly_Set_Up_Monitor_Colours_and_Brightness Also, this site mentions RGB cutoffs and gains, which I am not sure about. I have a Kortek KT-2603X chassis. There are colour pots on the chassis, and then colour pots on the neckboard. I am assuming one is the gain and one is the cutoff? Or is that totally wrong? :) Thanks for the help! Everytime I adjust the screen I get it to a good point, but then I am not fully happy with it, and I adjust it again and usually make it a bit worse :) Link to comment Share on other sites More sharing options...
