Fix it Felix Jr. arcade game from Wreck it Ralph movie can now be downloaded!
I am a big fan of the movie and have been hoping the arcade version would be released soon by someone. It's now online!
FYI, there are 3 versions of this game and I think the arcade version is the best.
1) This version which is from the Disney promotional arcade game, made in an arcade cabinet. Run from a PC. NO ROM. So NO MAME
See the arcade game version here:
http://www.youtube.com/user/MonsterFeetTV?feature=watch
2) There is a flash version on Facebook
http://apps.facebook.com/fix-it-felix-jr/?fb_source=search&ref=ts&fref=ts
3) There is the ios version for iPad and iPhone
- Download from itunes store
Download the arcade game from the link below.
ENJOY!!
I am sure you will! :)
DOWNLOAD:
http://files.arianchen.de/fix_it_felix_jr.zip
Hi AR,
Keys are the up, down, left and right arrow keys for up, down, left and right.
1 for 1 player start. 2 for 2 player start.
Space bar is jump.
C to insert coin.
SHIFT to use the hammer.
ALSO,
If you want to re-orientate the screen/make it larger for your cab, try the below. ENJOY!
Create a shortcut to the exe. Then right click the shortcut and click properties. You should see a long line in quotes that is the destination of the exe.
Example "C:/documents/games/fix it Felix.exe" after the quotes put in the command line options
Example:
-fullscreen -zoom=30 -rotate=90
Make sure you have the dash in front of it like above
Hi radirgyman,
Cool! Where did you see it? I used to live in Singapore and will pop over there in the next few months and would love to check it out!
It was at a major plaza that started with B from memory I think Buji?.. Ill have to ask my housemate, It was beside an escalator and not too far from it was an arcade joint on the very top floor of the plaza. But im pretty certain it had reck it ralph graphics on the cab which was a popeye nintendo cab converted.
Hi AR,
Space bar is jump.
C to insert coin.
ALSO,
Example:
Wish the maker included a config file. Really want to through this in my tabletop using Maximus arcade front end.
Anyway of changing the default keys somehow?
mj,
I had to download a program called Key Tweak. On my set up I had to change a button from CTRL to SPACE BAR. Key Tweak did the job easily enough. It's not ideal as you have to Restart to force the change and if you want to change it back you have to Restart again.
Unfortunately the download put a silly search engine program on my computer which I got rid of easily enough (thanks to Google).
I am not sure if someone will include a config file someday. I will post if i see one.
you can if you use autohotkey.
Hey mameshane. I have managed to change the keys to work with mame keys using autohotkey. How can I setup fix it Felix to close and the actual autohotkey script/completely close?
I am using Maximus arcade frontend and I want to retain my esc key to close both of these and return to the frontend game menu
EDIT:
Worked it out guys. If anyone is interested here is the autohotkey script I put together to get it to run with mame keys and exit on ESC key. Game directory needs to be located at C:\Felix
Run C:\Felix\FixitFelixJr.exe -fullscreen -zoom=30 -rotate=90
lCtrl::space
LAlt::LShift
5::c
esc::
WinClose, A ;
ExitApp
Return
And here it is running on my tabletop cabinet. Only thing is I only have a base P4 machine in there and it basically is so slow that it is not playable. Looks good though.
http://i1138.photobucket.com/albums/n532/jmicari/IMG_6975_zps9f63db6a.jpg
http://i1138.photobucket.com/albums/n532/jmicari/IMG_6974_zps1bbf3a25.jpg
http://i1138.photobucket.com/albums/n532/jmicari/IMG_6973_zps4f2f89ac.jpg
http://i1138.photobucket.com/albums/n532/jmicari/IMG_6972_zps0bb53191.jpg
Edited by mamejay
