Page 1 of 6 123 ... LastLast
Results 1 to 10 of 55
Thread: RAIL-WAYS Current Product List
    Dec 2006
    Central Coast,NSW
    9,838
    317 Post(s)
    1919 Post(s)
    As at 13/1/19
    Below is a list of some of the items that we have re-invented, aka these are 'repros' and not New Old Stock. The naming is only a reference point.
    WPC Rails;
    These are slightly wider (3mm) to cover side decals that may be damaged during removal or original bright art possibly showing.
    * Standard grained - $40pr.
    * Satin black powdercoat - $40pr.
    * Mild steel (so you can have them powdercoated yourself) - $35pr.
    * BA finish (brightly annealed) very shiny but not quite mirror or chrome - $50pr.
    WPC Hinges;
    * Grained stainless to match the standard rails - $50pr.
    * Satin black - $45pr.
    * Zinc steel (raw) , so you can powder coat to your choice - $35pr.
    BALLY Solid State Rails;
    * Standard grained with nail holes(The nail holes are offset approx. 3mm to allow driving into fresh wood -predrill wood 1st) - $50pr.
    * Standard grained -No Nails. Gives a smooth undimpled finish - $50pr.
    * BA finish (brightly annealed) in No Nails. I used these on my Harlem makeover. Very shiny - $55pr.
    * Inner "mirrors" done in BA to match the BA rails. Used these on my Harlem as well - $45pr.
    * BA set, rails and "mirrors" $90 for the 4 pcs.
    * Bally Medusa with extra flipper hole on the RHS and done in shiny BA finish with No- Nail holes - $55 pr.
    BALLY EM Rails;
    * Standard grained finish with nail holes - $45pr.
    * Standard grained finish with NO nail holes - $45pr.
    BALLY Solid State coin door blanks;
    * Brushed stainless and fit where coin slots used to be - $7ea.
    BALLY Solid State headbox transformer shields;
    * In raw Zinc steel finsish ready for powdercoating/chroming - $30
    * In powdercoated satin black - $40
    GOTTLIEB Rails;
    * Gottlieb System 3 Rails in BA (very shiny)no-nails finish - $50pr.
    * Gottlieb EM Rails - mid 60's -shorter version. Standard #4 grained finish. You will need to supply game name/measurements to make sure we have the right ones to suit - $35pr.
    * Gottlieb EM rails for widebody like Genie (1254mm). Standard #4 grained finish with nail-holes - $55pr.
    * Gottlieb EM Rails - mid 70's. (1317mm) Standard grained #4 finish with nail holes - $50pr.
    * Gottlieb EM rails - mid-lenght. (1287mm). Standard #4 grained finish - $50pr.
    GOTTLIEB Backcovers;
    * Gottlieb Wedgehead single player back cover. Galvanised steel, cross-breaked to stop warbling,lock barrel hole inserted at top - $60
    * Gottlieb 2 player EM back cover -70's. Galvanised steel , cross-breaked,lock hole at top. 625mm H x 703mmW - $60
    * Gottlieb 4 player EM back cover - 70's. Galvanised steel, cross-braked, lockhole at top. 675mmH x 700mmW - $60
    WILLIAMS Back cover;
    * Williams single player EM back cover '68 - '77. Galvanised steel, no cross breaking (flat) with lock hole at top. 640mmH x 552mmW - $60
    * Wiliams 4 player e.g. Rancho, Galvanised steel, no cross breaking (flat) with lock hole at top. 646mmH x 705mmW - $60
    WILLIAMS Solid State rails;
    * System 11B done in standard grained stainless - $50pr
    * System 11C done in standard grained stainless - $55pr
    * System 6 done in standard grained stainless and shiny BA finish (no-nails) - $55pr
    * Black Knight 2000 done in shiny BA finish in no-nails version with extra magna save flipper hole - $55pr
    WILLIAMS Solid State coin door blanks;
    * These fit in as infill plates after coin slots are removed and are done in slightly grained #4 finish - $7 each.
    ATARI Rails;
    * To fit Superman (may fit other Ataris) done in #4 slightly grained finish in NO-nails version - $60pr
    ZACCARIA Rails;
    * To fit Devil Riders (may fit other Zacc's) done in shiny BA finish with NO-nails version - $60pr.
    DATA-EAST Rails;
    * Satin black with wider finger protector to cover existing wear - $50pr
    * Satin black custom Jurrasic Park with T-rex laser cut into flipper wear area near button - $50pr.
    * Satin black custom Hook with laser cut art into flipper button wear area near button - $50
    * Mild steel versions of both the above in case you want to have them powdercoated your self to match lockdown bar - $40pr.
    CHROME PLATED LEGBOLTS
    * These are brand new legbolts which have been chrome dipped to give some bling to the legs. I usually only put them on the front but some have done all - $7each.
    CAB LEG PROTECTORS
    * These are made from 1.5mm thick Stainless Steel with 4 countersunk screw holes per protector. The set comes with a 16 pack of stainless screws - $50 a set.
    Please note we make these bespoke to suit a particular manufacturer and game era and in most cases front and rear are the appropriate length finishing about 5mm short of the cab base. For example WPC will not fit DE, DE will not fit Bally SS, Stern will not fit WPC and so on. If in doubt send me a measurement from the base of the cab to the centre of the bottom legbolt hole. So far we have done sets for;
    Bally EM e.g Captain Fantastic
    Bally solid State e.g. Fathom, Flash Gordon
    WPC e.g Fishtales, Roadshow.
    Stern e.g POTC.
    Sega e.g Frankenstein.
    Data East e.g. Hook
    BIBS AND BOBS
    * Return lane guides done in shiny BA for Flash Gordon, Firepower May suit other games?? $20 pr.
    * Getaway HSII rear diverter ramp flap. - $7
    * Repair base bracket for Flintstones concrete mixer plastic spinning disc. - $7
    * Bally solid state coin door reject button plunger - $10
    * We do these items as a hobby and can't see us retiring anytime soon -LOL and adding our own twist and ideas to them while trying to still stay intune with the games.
    * Please note that we try and keep a little of everything on the shelf and if need be we will try and fill your needs ASAP.
    * All rails that don't need nails you need to supply your own Doublesided tape. We have done this because it keeps down costs to you and also we can't be then held responsible if they won't stick due to polish residue etc.
    * We do discount for multiple orders.
    * We predominantly use PackandSend or Interparcel for freight whichever turns out the cheaper for you but you are welcome to drop in for a game or chat if you'd like.
    * We are always interested in remaking the the wheel so to speak so any and all input invited.
    Thanks for reading, Jeff & Mark.
    Last edited by Railways; 10th February 2019 at 06:42 PM. Reason: updated products list
    Jan 2009
    Cairns
    13,851
    456 Post(s)
    3734 Post(s)
    Jeff, those prices are fantastically cheap, well done
    Dec 2006
    Central Coast,NSW
    9,838
    317 Post(s)
    1919 Post(s)
    Quote Originally Posted by Homepin View Post
    Thanks Mike, I can always make them dearer so in fact Mark and I CAN retire.
    May 2013
    Queensland
    100
    1 Post(s)
    32 Post(s)
    Giddy JPD,
    Do you have a website or other form of contact so that I can view your items for sale thanks?
    Dec 2006
    Central Coast,NSW
    9,838
    317 Post(s)
    1919 Post(s)
    Quote Originally Posted by kirk332 View Post
    Giddy JPD,
    pm sent
    Aug 2010
    Adelaide
    84
    9 Post(s)
    postage cost for wpc rails to 5011.
    and if you have them, lockdown bar costs?
    cheers
    Dec 2006
    Central Coast,NSW
    9,838
    317 Post(s)
    1919 Post(s)
    LOL- I must have been typing a pm to you as you were typing this. Please refer to pm, Thanks.
    Aug 2008
    36
    8 Post(s)
    Hi Jeff
    Just wanted to say thanks!!! The WPC rails look great and you have been very helpful with organising delivery.
    Nov 2015
    Ontario
    1
    2 Post(s)
    Gottlieb System 3 Side Rails
    I'm hoping to get new side rails for a Tee'd off. Can you provide a price and shipping cost to Waterloo, Ontario, Canada (Not sure if your listed prices are in USD or AUD)?
    Thanks!
    Aug 2009
    Shepparton Vic
    5,604
    279 Post(s)
    1789 Post(s)
    Quote Originally Posted by Che View Post
    Thanks!
    Welcome to AA.
    Jeff's rails are very nice gear. @JPD
