Ponty Posted December 13, 2012 Share Posted December 13, 2012 Hi Guys Has anyone got ideas on how to put an external volume control (outside of cabinet) for the 60 in 1 board rather than using the test mode - as most of you know the sound level on these are all over the place Cheers Link to comment Share on other sites More sharing options...
Homepin Posted December 13, 2012 Share Posted December 13, 2012 You could use a wirewound pot in the speaker line. One like this ($22.95): http://www.jaycar.com.au/productView.asp?ID=AC1672 50 Watt RMS Fader - Mono These are ideal for controlling the volume of extension speakers, where they are in another room or location from the amplifier. These can be mounted in- line, or even in the speaker box itself. They have a constant impedance design suited to 8ohm systems.Supplied with plastic face plate. Rated at 50W RMS. Link to comment Share on other sites More sharing options...
gameroom Posted December 13, 2012 Share Posted December 13, 2012 60 in1 volume control I put controls on the inside by using the line out going to a small amp running on 12v. The amp is mono but so is the 60in1. I could not find a photo on my phone for one, but here is the stereo one I use for mame. Similar but has tone and base as well as volume. Link to comment Share on other sites More sharing options...
Ponty Posted December 14, 2012 Author Share Posted December 14, 2012 You could use a wirewound pot in the speaker line. One like this ($22.95): http://www.jaycar.com.au/productView.asp?ID=AC1672 50 Watt RMS Fader - Mono These are ideal for controlling the volume of extension speakers, where they are in another room or location from the amplifier. These can be mounted in- line, or even in the speaker box itself. They have a constant impedance design suited to 8ohm systems.Supplied with plastic face plate. Rated at 50W RMS. Thanks - Will give that a go Link to comment Share on other sites More sharing options...
Boots Posted December 14, 2012 Share Posted December 14, 2012 here is a schematic, normally I reckon it's a 100k pot. Link to comment Share on other sites More sharing options...
Homepin Posted December 14, 2012 Share Posted December 14, 2012 here is a schematic, normally I reckon it's a 100k pot. [ATTACH=CONFIG]45786[/ATTACH] Not 100K for wiring into the speaker line - usually VERY low around 8~15 ohms. Link to comment Share on other sites More sharing options...
Boots Posted December 14, 2012 Share Posted December 14, 2012 Not 100K for wiring into the speaker line - usually VERY low around 8~15 ohms. My Bad, I just checked, it's 100ohms not 100kOhms This is what's in my LAI machines Link to comment Share on other sites More sharing options...
Homepin Posted December 14, 2012 Share Posted December 14, 2012 My Bad, I just checked, it's 100ohms not 100kOhms This is what's in my LAI machines 100 ohms will work but it is too high in value IMO. Picture what is happening - you are REPLACING the load of the speaker with the OUTSIDE terminals of the pot. The pot is now the "load" as far as the amp is concerned (and this is why it must be a wirewound type of pot). The amp is expecting to drive a load of between 4~16 ohms - this is what value the pot should be. You are then taping of at different points of the pot and taking this to your speaker. This is simplistic because the higher you turn the volume - the more you are changing the impedance of the load to the amp as you are introducing 'more' of the speaker into the picture. To compensate for this most pots used in this application are double the value. Link to comment Share on other sites More sharing options...
ostybeef Posted January 10, 2013 Share Posted January 10, 2013 Hey, sorry to hijack but I'm looking for a volume pot for a couple of my machines but didn't want to use an amped version. I just went to jaycar and asked if they had a pot which is 4~16 and he looked at me like I had 2 heads and told me they don't make em that small. What should I be asking for or don't they sell that kind of thing in jaycar? Link to comment Share on other sites More sharing options...
Homepin Posted January 10, 2013 Share Posted January 10, 2013 Hey, sorry to hijack but I'm looking for a volume pot for a couple of my machines but didn't want to use an amped version. I just went to jaycar and asked if they had a pot which is 4~16 and he looked at me like I had 2 heads and told me they don't make em that small. What should I be asking for or don't they sell that kind of thing in jaycar? http://www.jaycar.com.au/productView.asp?ID=AC1672 Jaycar part number AC1672 Link to comment Share on other sites More sharing options...
