FS: * * * * Atari Colour Vector Deflection Bare PCBs, Amplifone * * * *
Following on from the prev. thread, these have been ordered and are heading to me soon, from the board maker (Next few weeks)
FOR SALE: Brand new Deflection PCB (Unpopulated, Bare), to suit Colour Amplifone monitors
These are tested, ready to go IE: (Taking orders/Pre payment)
This is what is for sale (Similar Prototype)
http://www.amazingarcading.com.au/2013_Proto-05-sm.jpg
This is what it looks like after you assemble it
http://www.amazingarcading.com.au/2013_Proto-03-sm.jpg
After months of testing we have a vastly improved PCB. Dozens of improvements have been made during assembly of this prototype.
If you need a parts list, here it is
http://www.dsbelec.iinet.net.au/Icon_DeflParts.jpg
Some of the improved labels
http://www.dsbelec.iinet.net.au/Defl_Labels-sm.jpg
Introductory cost of the bare unpopulated PCB will be $60.00
Please paypal me using derricksb@iinet.net.au
Please include a Paypal note with:
AA User Name
Your Quantities
Name
Address
Phone Number
You may need a large heatsink too. An option is available
A suitable heatsink replacement is available at Jaycar HERE
You can fit a fan to this new type of heatsink if you want (Optional)
http://www.dsbelec.iinet.net.au/Fan-01-sm.jpg
A 12V Fan can be powered from the board itself using a 7812 Regulator and small heatsink (Optional extra)
http://www.dsbelec.iinet.net.au/Amp_Dez_Gerber_11-sm.jpg
Today I drilled out the 4 base plates for the Amplifone Heatsinks Gibo had made for me (Cheers mate)
These are for use with the Jaycar heatsink like Gibo and I have done
Aussies who buy the PCB will get priority. $35.00 plus shipping for each plate (You buy the Jaycar part locally of course)
I will be putting them on my website in a few days opening them up to other countries
http://www.dsbelec.iinet.net.au/Heatsink_Baseplate-01-sm.jpg
http://www.dsbelec.iinet.net.au/Heatsink_Baseplate-02-sm.jpg
Jaycar heatsink is here
http://www.dsbelec.iinet.net.au/Jaycar_HH8532_H-Sink-icon.jpg
NOTE It's a good idea to use heat paste when fixing the 2 x metal parts together :D
Those who expressed interest in the old thread are below, let me know if you still want anything
Gibo 2 (Already sorted)
daveb PAID x 1
Hoopstar 1 OR 2
Thank you
EDIT:
The New Boards Have Arrived!
http://www.amazingarcading.com.au/amp_defl_final-01-sm.jpg http://www.amazingarcading.com.au/amp_defl_final-02-sm.jpg
One will be assembled to make sure :)
Edited by dezbaz
still in for one... maybe 2 :)
Awesome work Dez!!
Thanks guys . . :)
No probs
So, are you after a 25" and then poss a 19" Tube? (Or just 2 x Deflection PCBs)
Edited by dezbaz
All arvo I have been assembling the Deflection board. Every part is new this time - for the first time
Home made heatsink
Big Transistors
Connectors
Some Big Parts
Lots of resistors
End result so far . . . .
http://www.dsbelec.iinet.net.au/First_New_Amp_Defl-02-sm.jpg
**** Notes people: ******
No insulators under the screws of the Large T03 Transistors, as they need to conduct through to the board
I used a meter to ensure no transistor was touching the Heatsink. The 2 inner resistors can touch the heatsink, as they are internally insulated. Hense: No insulator is needed at all - screws or mounting.
More updates Tomorrow I would think
I assembled one fully from scratch, plugged it in, turned it on (Double checked for solder bridges, and bits of wire etc)
The result - ALL Good!
This screen is not converged - I rushed it together for the prototype testing
http://www.dsbelec.iinet.net.au/Final_Test-01-sm.jpg
http://www.dsbelec.iinet.net.au/Final_Test-02-sm.jpg
http://www.dsbelec.iinet.net.au/Final_Test-03-sm.jpg
Those who have paid can expect theirs soon
Cheers Gibo
I have NO spare TO-3 Trannies Gibo, have you got any for your 2 boards mate?
I am ordering some now, but they may not arrive in time
You will have some, from Bob Roberts
2 x 2N3716 (Proven higher rated Alternate = 2N5886)
2 x 2N3792 (Proven higher rated Alternate = 2N5884)
Edited by dezbaz
  • Super Moderator
I spent yesterday with Dez assembling my 2 deflection boards,the through hole design makes it very is to solder in the new parts and all is clearly marked on the board.As you can see in the pics I went for the Jaycar heatsink attached to a 5mm ali plate,one problem i did have was trying to isolate the mounting screws from the heatsink for the TO-3 packages but overcame that by drilling out the holes in the heatsink to 1/4 and using some 1/4od plastic airline cut to 5mm lengths and inserting them in the enlarged hole,problem solved.
All Tested and working
Good job Dez
http://i568.photobucket.com/albums/ss128/truckrepairs/IMG_0278.jpg
http://i568.photobucket.com/albums/ss128/truckrepairs/IMG_0279.jpg
Edited by dezbaz
