60in1 "Out of range" problem on monitors
Got a few 60in1's, and finally got to the stage of finishing off the first of 3 little bartop cab I built for them to sell off.
Wired up the power supply and hooked up the board to the monitor, and the screen flashes up - "Out of Range"
I have checked the 2nd DIP switch - its on "ON" for VGA screens
I plugged this into another LCD screen to double check ...... same thing on this one.
I feel its just the monitors not handling the 31.5Khz coming from the 60in1
....Now.... after more fiddling....
Double checked the cards on a CRT monitor I have laying about - works good.
Plugged it back into the bartop and now the screen flashes up for a second every 5 seconds of the card working (you can see the count-down as it initialises, and then the menu screen) .... this has got me totally stuffed !! :unsure
[ATTACH=CONFIG]45277[/ATTACH]
What size screen are you using?
There were some 60in1 boards going around that don't work on 15inch VGA CRT or LCD screens.
Check the picture with a bigger screen like a 19 or 20 inch LCD if you have one.
I am not sure about 17inch LCD screens.
If it is one of those boards you may have to change it for another board.
If you know someone who is running a 60in1 on an arcade screen of any size you could swap it with them.
  • Super Moderator
I think it comes down to refresh rate of the monitor.. I dunno :unsure but I've experienced the same problem.
It came down to:
Newer board + older monitor = not ok
Newer board + newer monitor = ok
Older board + older monitor = ok
