Likes Likes:  0
Results 1 to 6 of 6
Thread: rowe R-91 Volume
    Jan 2012
    Florida
    6
    rowe R-91 Volume
    I have a R-91 jukebox and when I went to listen to it the volume was at its almost lowest.When I tried to turn it up I had nothing.I replaced the volume pot and still nothing.Is there anything I can check on the amp or any other suggestions
    May 2009
    Munruben (Brisbane)
    120
    2 Post(s)
    19 Post(s)
    Check all the spade connections on the door above the amp. If still no volume then replace the darlington type transistors on the amp. Worked for me
    Jan 2012
    Florida
    6
    Thank you very much.What do you mean by the darlington transistors
    Jan 2012
    Florida
    6
    Ive noticed on the amp itself it is not warming up.The heat shield is cold.Would that have anything to do with it.In the 1st pic the plug is unplugged.I had that unplugged to remove the amp
    May 2009
    Munruben (Brisbane)
    120
    2 Post(s)
    19 Post(s)
    Try arcadecontrols.com There are two rowe/ami techs use that forum
    Jan 2012
    Florida
    6
    I have replaced the 4 transistors and the volume got clear but I still can not adjust it.Ive also replaced the output transformer and still the same.Would anyone have a pic of the wiring diagram for the connections on the door above the amp
