Junior Posted September 29, 2011 Share Posted September 29, 2011 Hi All, I made a cocktail cabinet some time ago now and all was completed except one thing, which has been put off for too long Ive never installed Glass clips to hold the top together I remeber the ones available and around at the time of my build had been the correct size, but the underneath and connection to the mdf top was not long enough and you would be screwing them into the t-mold Havent had much recent luck in finding anything around that would suit The top is 16mm, and glass is 6mm, even though thats 22mm a measurement check looked more like 24mm Possible due to artwork or maybe the way its sitting somehow Just a simple C like clip would be perfect, just need that bottom part to be longer and probably around 15-20mm The top can naturally be much shorter, enough to hold glass well Any direction would be much appreicated, nothing worse than having a build at 99% Thanks Link to comment Share on other sites More sharing options...
Super Moderator WOKA Posted September 29, 2011 Super Moderator Share Posted September 29, 2011 Gamedude.com.au who was (?) a site sponsor sells cilps for $19.00 Code: arcCLIPset Price: $19.00 Detail: Table Top Glass Clips SET of 4 Supports maximum material thickness of 28mm including glass, If total thickness is less than this foam inserts can be used between the glass and clip. Flat BLACK powder coated comes with screws. Picture: I'd post the URL of the site, buy I can't see it to copy it.. Hope this helps. Link to comment Share on other sites More sharing options...
Junior Posted September 29, 2011 Author Share Posted September 29, 2011 Hey Woka, These are quite common I've noticed, and I wish they would work Unfortunately the way the top is and its curves, these would not work Actually I realised ive said I need a "C" type, probably more sideways U Side profile needed would be ---------- | | | | ------------------------- Ive noticed In2AMusements has these classed as basic clips / out of stock Ive sent a email to find out the height and length of the bottom piece, as the draw back so far has been the bottom being too short and the screw would simply not go in to the mdf but the t-mold slot and t-mold itself (which isnt ideal) Link to comment Share on other sites More sharing options...
Jaympee Posted September 29, 2011 Share Posted September 29, 2011 I need a set aswell. I noticed Gameroom has used them on his Midway style cabs, but couldnt find the clips on his website. Think I will try a PM. Link to comment Share on other sites More sharing options...
gameroom Posted September 29, 2011 Share Posted September 29, 2011 I make my own as I could not find any decent ones to suit the sizes I needed. Many people have been asking for them on other forums, but its hard to put a price on them due to the length of time to make them. These are hand made, so if the clip is out by 0.25mm then the clip is either too tight or too loose. But generally get 6 good ones from 8 made. I did make a thread about how to make them, but not sure if I did one on this forum. Here is a thread from another forum which shows how to make them. I use a panbrake, but you could use a vice. http://www.awrtguma.com.au/viewtopic.php?f=6&t=327 Link to comment Share on other sites More sharing options...
