Page 1 of 11 123 ... LastLast
Results 1 to 10 of 110
Thread: Dedpin : 46" 46" 2 screen pincab build : an ongoing saga
    Mar 2011
    Newcastle Australia
    6,311
    373 Post(s)
    1909 Post(s)
    While I have so many other projects on the go, why not another one.
    I have had a temporary setup going for a while now , so it was time to start building the cab.
    Heres some of what has been done over the last couple of weeks.
    Knocked together a cab
    Debezelled 2 x 46" LCD screens
    Fit screens into the cab
    Measured up for the back box, then assembled one
    Tested everything for fit and did some table beta testing
    Cut and fit some of the backbox trim, to suit the newer style of BG locking
    Enjoyed a few games on the huge BG
    Thats it so far
    If you like, you can check out the complete build process here http://www.vpforums.org/index.php?showtopic=14823&st=0
    cab build 1023.JPGcab build 1027.JPGcab build 1045.jpgcab build 1059.JPGcab build 1064.JPGcab build 1149.JPGcab build 1150.JPG
    UPDATE
    (full build copied over from VPF)
    I finally made a start on the cab build.
    I already had the computer built and everything set up and working for months now.
    Time to put it in a cab.
    i7 3.06 ghz
    x58A UD 3R mother board
    2 x GTS250 (16x/16x)
    4gb Ram
    700w PSU
    500 gb hdd
    All thrown together in a half case
    the initial testing on a 42" Sharp Aquos looked amazing
    Scored some ply from the last job I worked at and it just happened to be the right lengths.
    I measured up Judge Dredd and cut the sides and measured the screen for the width.
    Still debating whether to rout slots in the sides to house the screen, but for now I left it wider and installed
    temporary guides to sit the 46 on to gauge the height and position.
    Got the screen heights measured up. Works out that the backbox height will be near identical to Guns N Roses
    Did some rough measuring and there should be enough height to have a drawer tray out the back, under the vertical screen.
    Also a full sized backbox glass with lift channel and painted surround to hide the bezel.
    With a little bit of modifying, the lockdown bar locking mechanism can be made to fit so that the bar covers the whole bezel. Huge side edge bezel of 35mm.
    Decided to go with the old school look. Tried the back box from Gottlieb Spirit of 76, few mods and it will be fine. I will be making it from scratch, that head box has a home.
    Started some wiring from stuff I have laying around.
    I'm using a line filter IEC socket that I had in a driving game power supply hack as my 240v feed. Wired it to go to the 1st power socket for the computer to plug into. Also using a 240v plug to 2 x IEC plug splitter cable for the 2 LCDs.
    Made up some power switching units using relay and din rail components as well.
    I found this cool motorized USB hub. Don't know if I will put in in the front or underneath at the side. Either way, it will make life easier.
    The Artist Formally Known As #1
    Jul 2008
    adelaide hills
    3,265
    3 Post(s)
    186 Post(s)
    giddyup! i'd love to a play on one, they look neat. good stuff
    Oct 2005
    In a house, Ipswich, Sunny Qld
    4,057
    2 Post(s)
    35 Post(s)
    Nice work, just reading the vp forum build log now
    Apr 2006
    Brisbane - Wakerley
    7,836
    93 Post(s)
    477 Post(s)
    Looks cool, I don't think I've seen anyone use a screen that big for a back glass
    Jan 2009
    Cairns
    13,851
    456 Post(s)
    3734 Post(s)
    very neat - how did you configure the backglass monitor to ONLY use the top half of the screen??
    Mar 2006
    Brisbane, Australia
    11,548
    189 Post(s)
    1440 Post(s)
    The software allows you to adjust the backglass picture to suit the size of the monitor
    Brad
    Jan 2009
    Cairns
    13,851
    456 Post(s)
    3734 Post(s)
    Quote Originally Posted by Brad View Post
    Brad
    Yes, I read through the VP forum and had a browse through the other stuff - WAAY too complicated for this L'il Black Duck - I'll wait for the Chinese "60in1" VP Pin board to come out
    Mar 2006
    Brisbane, Australia
    11,548
    189 Post(s)
    1440 Post(s)
    LOL. Actually it's not that bad and once you've set it up it's all done.
    Heres a well written tutorial on how to set it all up.
    http://www.hyperspin-fe.com/forum/sh...light=tutorial
    Cheers,
    Brad
    Nov 2005
    Drouin VIC on the move ;)
    7,901
    33 Post(s)
    350 Post(s)
    Nice one with the backbox screen would never have thought about that (out of my price range)
    The best action is wrist action!!!!!!
    Apr 2006
    Launceston, Tas
    10,947
    93 Post(s)
    477 Post(s)
    Impressive
