Railways Posted February 13, 2011 Share Posted February 13, 2011 Mini playfield gearbox has stripped a gear. anyone got a gear box that might still be ok?? I can get a new one from PSP or mad as a last resort, cheers Jeff Link to comment Share on other sites More sharing options...
rocky2 Posted February 14, 2011 Share Posted February 14, 2011 Hi Jeff My DW gearbox had the same problem. I couldn't use it so I drilled the rivets to get the cover off. i found that one of the gears was slipping on the shaft. I took it to a friend who braized them together again. Used nuts and bolts to put the cover back on. This happened about 4 years ago and it hasn't missed a beat since. Cheers. Link to comment Share on other sites More sharing options...
Railways Posted February 16, 2011 Author Share Posted February 16, 2011 Hi Jeff My DW gearbox had the same problem. I couldn't use it so I drilled the rivets to get the cover off. i found that one of the gears was slipping on the shaft. I took it to a friend who braized them together again. Used nuts and bolts to put the cover back on. This happened about 4 years ago and it hasn't missed a beat since. Cheers.Thanks Yee, Exactly the same happened with a mates Dr. about 2years ago and I did exactly the same thing but alas this time on this one after disassembly it has one large gear that is missing about 15 teeth which is beyond repair - looks like I've got spend some coin<_< Link to comment Share on other sites More sharing options...
Super Moderator stuba Posted February 16, 2011 Super Moderator Share Posted February 16, 2011 hi jeff pretty sure i can help you with that. i have 2 playfields and 2 mini playfields. i did swap one mini for the other (they both were working from memory). i'll check for you. prod me next week if i don't get back to you. stu Link to comment Share on other sites More sharing options...
Railways Posted February 17, 2011 Author Share Posted February 17, 2011 hi jeff pretty sure i can help you with that. i have 2 playfields and 2 mini playfields. i did swap one mini for the other (they both were working from memory). i'll check for you. prod me next week if i don't get back to you. stuAah excellent, Ta stu - good luck with the hunt in the shed. I'll come and give you a hand:D (I feel warm and fuzzy in there:lol) or that may have been the bourbon:lol Link to comment Share on other sites More sharing options...
Super Moderator stuba Posted February 17, 2011 Super Moderator Share Posted February 17, 2011 Aah excellent, Ta stu - good luck with the hunt in the shed. I'll come and give you a hand:D (I feel warm and fuzzy in there:lol) or that may have been the bourbon:lol I just love sucking in the air down there. Alas, though, it is no excuse for a visit because the spare is sitting under the machine in the games room (I think - i know the main playfield is anyway, surely the mini is with it ;) Link to comment Share on other sites More sharing options...
Railways Posted February 17, 2011 Author Share Posted February 17, 2011 I just love sucking in the air down there. Alas, though, it is no excuse for a visit because the spare is sitting under the machine in the games room (I think - i know the main playfield is anyway, surely the mini is with it ;)I will wait with baited breath Alby:D Link to comment Share on other sites More sharing options...
Railways Posted February 24, 2011 Author Share Posted February 24, 2011 Ta stu for having a look for me:). It looks like its off to order from O/S and see what happens:( Link to comment Share on other sites More sharing options...
