- 0
Switch matrix issues
Recently Browsing 0 members
robm
I have a FishTales where switches 34,44,54 and 64 don't work - yet 14 (tilt) does and 24 is always closed (as should be).
I've done the tests on pinrepair jumpering across 207 and 209 and they test OK, so this should indicate the problem is on the playfield rather than the CPU (i replaced U20 and 18 anyway).
I can get continuity from the white/yellow wire from switch 14 (tilt) to CPU connector J212, but can't get any continuity to this pin from any of the other switches. Continuity between switches 34,44,54 and 64 is fine, but none between any of these and 14.
What i have also discovered that may help is that when testing the corresponding diode D21 on the Coin door interface board (just near the tilt mechanism), is that it tests as 0.9V when all the others test OL (when reading the other way for the diode test they all test OK at 0.5V) If i disconnect plug J1 from the coin door interface board, this diode tests OK (i have replaced this diode as well), so does this indicate a problem with one of the switches or wiring downstream? ie: switches 34 - 64.
I tested each of these switches one by one and they all work OK (continuity when closed, none when open).
What i can't work out also is that the yellow/white wire from J1 on the coin interface board seems to go straight to CPU J212, but can't see where this all joins to the yellow/white wire for switches 34-64.
I'm tempted to jump this yellow/white from 14 to 34 and see what happens - is this a bad idea?
Thanks
Rob
2 answers to this question
