Likes Likes:  0
Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 45
Thread: MGL - X Game 8: Bomb Jack (Set 1) (Tehkan)
  1. #11
    Apr 2006
    Launceston, Tas
    10,576
    93 Post(s)
    477 Post(s)
    Quote Originally Posted by wingtipvortex View Post
    I think we play with the dips on medium, thats what ive played this game on.
    Dk, can you confirm what settings mate.
    Both MAME default dips I have are
    Lives 3
    Bird Speed Easy
    Enemies Number & Speed Medium
    Special Coin Easy
    I couldn't do the dips last night as I wasn't close to a MAME setup
    Also the rom is bombjack , game is (Set 2), I will update the first post
  2. #12
    Nov 2006
    WA
    921
    34 Post(s)
    127 Post(s)
    Quote Originally Posted by DKong View Post
    Lives 3
    Bird Speed Easy
    Special Coin Easy
    Thanks for the update - Thats the settings Ive always played on even in the arcade!
    Mame has updated the defaults to hard, hard, easy - which also matches the factory defaults according to the manual!
    I'm playing on my original board so I wanted to make sure I got the right settings
  3. #13
    Apr 2008
    Tasmania
    4,246
    232 Post(s)
    1279 Post(s)
    In my mame 0.135 it says that (bombjack)rom is set1 and that set2 (bombjack2)rom is a clone of set1
    Also noticed that when I checked the dips there was an option to change the scores to get a free man. This should be set at "none".
    Last edited by Rat; 17th February 2010 at 06:59 AM. Reason: Auto Merged Double Post.
  4. #14
    Apr 2006
    Launceston, Tas
    10,576
    93 Post(s)
    477 Post(s)
    Quote Originally Posted by Rat View Post
    Thanks Rat, Is there any difference between Set 1 and Set 2 should we play Set 1
  5. #15
    Apr 2008
    Tasfunkia
    6,271
    37 Post(s)
    261 Post(s)
    Been playing set 2 for some time, downloaded set 1 and played for a couple of hours, cant see any difference Maybe go set 1 as thats what they play on Twin Galaxies.
    I cant seem to find anywhere on 1 or 2 to adjust a free life? There is an option to adjust default high score though. Its set on 10,000 by default.
  6. #16
    May 2009
    NSW
    6,223
    161 Post(s)
    1433 Post(s)
    283,450
    Booya! Cracked 100k
    I'd forgotten what a fun game this is, always wished I knew more about it. The game has a real nice combination of chaos and precision that makes it so playable.
    Q: Should you always try to get the bombs in 'lit' sequence ? This seems to set off the 'P' bonus earlier...and is there an easy way to get the 'B' bonus come out sooner?
    Edit: Score update
  7. #17
    Apr 2008
    Tasfunkia
    6,271
    37 Post(s)
    261 Post(s)
    Quote Originally Posted by Jammasized View Post
    Booya! Cracked 100k
    If you get the lit bombs in sequence, you will receive 50K at the end of each level.
    So by the end of level 2 , you will have cracked 100K+
  8. #18
    May 2009
    NSW
    6,223
    161 Post(s)
    1433 Post(s)
    Wow....! thanks for the tip. It took me 14 levels to get my 150k
  9. #19
    Apr 2006
    Launceston, Tas
    10,576
    93 Post(s)
    477 Post(s)
    The adjusting free life comes out in later MAME versions for some reason, just set it to none if anyone is running this version of MAME.
    Booya! Cracked 100k
    The P comes out once the bar at the top of the screen maxes out (around the X bonus you are on) I think the lit bombs increase it quicker.
    Also the B comes out every 5000 points so if you are close to a 5000 point multiple flap your wings (wiggle joystick) against sides to get small point increases.
    Thats right learning the patterns helps but the lit bombs are lit one after another in rows..
    Last edited by DKong; 17th February 2010 at 01:29 PM. Reason: Auto Merged Double Post.
  10. #20
    Nov 2006
    WA
    921
    34 Post(s)
    127 Post(s)
    The older version (set 2) says 'YOU ARE LUCY' instead of 'YOU ARE LUCKY'. when you collect the special - no game play difference.
    The free life setting is to do with the first three switches on dip2 - the manual states these should be left off. Someone must of figured out what they did 'ie bonus life @ 100k' so it was added to mame in later versions.
  1. Replies: 46
    Last Post: 18th January 2010, 06:54 PM
  2. MGL - T9 Game 10: Exerion
    By DKong in forum MGL Tournament 9
    Last Post: 5th October 2009, 08:34 PM
  3. MGL - T9 Game 5: Donkey Kong (US Set 1)
    Last Post: 6th September 2009, 06:07 PM
  4. MGL - T9 Game 4: Galaga
    Last Post: 1st September 2009, 02:23 PM
  5. Tech word
    By CRAZED in forum Arcade Technical and Repair Questions
    Last Post: 11th April 2007, 09:05 PM
