Likes Likes:  0
Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Thread: auto turn on atx power supply with capactitor
    Jul 2006
    Townsville, North Qld
    11,792
    1 Post(s)
    2 Post(s)
    finally found this again
    converted to pdf and attached
    can we sticky this please
    converted original pdf at 465 kilobytes to djvu, now only 88 kilobytes
    djvu reader for windows in a post of mine further down
    Ubuntu User #16304 Linux User #450903 rc forums ultimaterc.com looking for cabinet plans?click here pc atx power supply for 12/5 volt for mame cabinet and turn it on auto-magically? click here
    if your new to electronics and want to learn more, click here **how to attach images to posts click here** my youtube channel
    Nov 2006
    Perth, Australia
    4,489
    122 Post(s)
    521 Post(s)
    Just to add to this if you use an ATX P/S instead of a switching P/S for your arcade cab and want it to turn on when you power up the cab find the green wire inside the 20 pin plug loom and cut it off at the plug end then just ground it permantly
    Jul 2006
    11,792
    1 Post(s)
    2 Post(s)
    i went hunting and found a photo that shows how to force atx power on by modify the wiring of the atx power supply as well. this mod will be great if you use the atx psu to power a car amp for your mame cab
    photo attached
    also, check your pc bios there is on newer boards a setting you can change so that it will restart after power loss
    Jul 2006
    11,792
    1 Post(s)
    2 Post(s)
    also went hunting and found a tutorial on how to convert an atx psu in to a benchtop power supply
    i tried to convert it to pdf, but at 150 dpi it was 8 megabyte in size!!!
    so i converted it to djvu format instead and the same file is now about 250 kilobyte long
    get a freeware viewer here
    http://windjview.sourceforge.net/
    if u use ubuntu, theres a djvu reader built in to it
    the file attached i had to convert to a pdf or the forums would not upload it
    also attached "the fix"
    the fix will describe how to put on a dummy load to the psu to keep it running. some atx psu will not run if a load is not on there and shut down
    Attached Files Attached Files
    Jul 2006
    Melbourne, Victoria
    1,091
    1 Post(s)
    6 Post(s)
    thanks this is just what i was looking for
    Jul 2006
    11,792
    1 Post(s)
    2 Post(s)
    Quote Originally Posted by IMPURE View Post
    excellent
    there was someone else the other day who made a post and wanted to know about auto turn of of atx psu's
    that was what reminded me to go hunting the net and save it in pdf or djvu for future reference for all of us
    Mar 2008
    Sydney (Normanhurst)
    4,767
    6 Post(s)
    6 Post(s)
    The cap trick is a bit different to the green to black ATX power on.
    To clarify:
    The cap trick is used to turn on a motherboard/pc without having to press the powerbutton.
    The "green to black" trick is to power up the power supply without needing a motherboard (to use as a bench supply or an arcade psu).
    Thanks for posting the cap trick - I had forgotten all about it!
    Oh, and the polarity of the cap - why is that important? If it is hooked up backwards, it will heat and then boil internally over time, and then go off like a firecracker
    Jacob
    Jul 2006
    11,792
    1 Post(s)
    2 Post(s)
    Quote Originally Posted by AskJacob View Post
    Jacob
    it wont blow up...not enough current for it to do that
    the capacitor in this case is being used as an "electronic switch" so to speak
    if wired up back to front,it wont work, plain and simple
    How It Works:
    A capacitor's discharged state is shorted. When you apply power to the unit,
    the cap acts as a short between the pins, activating the power supply.
    With 5V flowing through the cap, it's shorted state becomes an open state,
    allowing the board to boot normally.
    When you power down the unit, the capacitor will discharge, and resume its shorted
    state, allowing it to do this the next time you power up.
    Aug 2007
    Victoria Point (Brisbane)
    4,853
    21 Post(s)
    130 Post(s)
    It might not blow up, but it will fail (possible shorted) if subjected to reverse polarity for too long.
    "Everyone's always in favour of saving Hitler's brain. But when you put it in the body of a great white shark, ooohh! Suddenly you've gone too far!"
    Jul 2006
    11,792
    1 Post(s)
    2 Post(s)
    Quote Originally Posted by Mickey Juice View Post
    No offence intended, but what's wrong with PDF?
    Just re-distil at a lower quality...
    the big difference between pdf and djvu is filesize
    djvu uses a lossy format similar to jpeg to save files
    the picture quality is just as good as pdf, but the file size is usually a hell of a lot less then pdf
    why bother to recompile documents at a lower quality when you can get almost the same quality and much smaller document size using djvu?
    last year i spent 6 months scanning and converting over 6000 pages of old computer magazines to pdf format
    i kept the pdf format and converted the lot to djvu and usually the djvu file come in at under 10% of the original file size with quality just as good as the pdf and uploaded the djvu format to ftp servers in the usa for others to share & use.
  1. Power Supply FAQ
    By Berty in forum PCB and Monitor Repair logs
    Last Post: 14th April 2017, 12:04 AM
  2. Peter Chou Power Supply F10214288
    By immortal in forum PCB and Monitor Repair logs
    Last Post: 3rd April 2009, 08:48 PM
  3. Powering extras from a PC power supply
    By tardisx in forum Mame Cab Hardware and Software Discussion
    Last Post: 16th May 2008, 03:31 AM
  4. Power supply question
    By mozzie in forum Arcade Technical and Repair Questions
    Last Post: 13th March 2008, 02:40 PM
  5. Power Supply Question
    By MaddogDU in forum Arcade Technical and Repair Questions
    Last Post: 4th March 2008, 07:01 AM
