Likes Likes:  0
View Poll Results: Should Battlezone be added to the games list for MGL X ?
Voters
17. You may not vote on this poll
  • Yes
    9 52.94%
  • No
    8 47.06%
Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Thread: Battlezone
    Apr 2009
    NSW
    448
    2 Post(s)
    Battlezone
    Nothing like a bit of controversy to add spice to your day.
    Should Battlezone, an arcade vector classic from 1980, be added to the games list for MGL X ?
    Dedicated cab uses 2 two-way joysticks ( up and down ) and one button.
    This'll sort the keyboard players/two-player cab owners from the one-stick/cocktail contingent.
    Apr 2006
    Launceston, Tas
    10,576
    93 Post(s)
    477 Post(s)
    Quote Originally Posted by shabu View Post
    Should Battlezone, an arcade vector classic from '82, be added to the games list for MGL X ?
    So if you use an 8 way joystick can you configure it to be l/r, u/d and then the diagonals will be forward left, forward right etc
    Edit and I will need the Mame ini resolution settings for running this on an Arcade monitor so it at least slightly resembles vector resolution
    May 2009
    NSW
    6,217
    161 Post(s)
    1432 Post(s)
    Dkong it should run fine as is, we've played other vector games before with no problems (Asteroids Deluxe in MGL9 springs to mind)
    If not give me a yell, I'll have a look at my ini file and let you know, it will help to simply bump up your 'Beam' setting in the vector settings of your mame.ini a bit for most vector games if you're running an Arcade Monitor (I am.) You wont need to touch the 'flicker' or alias settings though, just the Beam.
    Edit: YAY 6 to 3 so far in favour.
    Apr 2009
    NSW
    448
    2 Post(s)
    Six votes apiece. Well that's more-than enough people saying they don't want to play it so I withdraw my nomination.
    Would be interesting to know if those who didn't want to have it included are using a one-stick cab / cocktail or said no for some other reason.
    I'm looking to play the tourn on a two player upright so config isn't an issue for me in that i've two sticks to use.
    I'm sure it'd be a different story on a keyboard but not sure what people are using for the tourn.
    Nov 2005
    229
    14 Post(s)
    Due to this thread I actually fired up Battlezone for the first time on my cabinet.
    Dual joysticks, being a 2P candy - so controls were as "normal" and I set up P2 button 1 as fire - simply as it felt more comfortable to use my right hand to fire.
    I sucked - but I think it'd be workable for general play.
    Frankie
    May 2009
    NSW
    6,217
    161 Post(s)
    1432 Post(s)
    Nooooo! It's got till December 2 to close...why throwing in the towel before the final bell has tolled ?
    I'm assuming 'majority rules' in a poll so all BZ needs is a majority vote - or how does this work DK on the polls ?
    I also have a two player cab and it's great with two joysticks. Just for interests sake I mapped a+b buttons for left and right, c button for fire, and used a single joystick for forward and back, and the game was just as playable as it is with two joysticks.
    Don't really mind though, it's all good, Mame is the winner, and we will fight them on the beaches with or without vector tank battles.
    Mar 2006
    Brisbane, Australia
    11,472
    203 Post(s)
    1505 Post(s)
    Apr 2008
    Tasfunkia
    6,271
    37 Post(s)
    261 Post(s)
    Its probably easier on a keyboard, all movement is with one hand on keys. Robotron on the other hand is near impossible without 2 joysticks. Can be done, but very complicated....which takes the fun factor away imo.
    Apr 2009
    NSW
    448
    2 Post(s)
    Quote Originally Posted by wingtipvortex View Post
    You have a point there... DKong - Robotron is also on the list but there's been no feedback about it till now. If people are not keen on Battlezone ( 7 for - 8 against at the moment ) then this would also affect the choice of Robotron I'm gathering.
    Very close in the voting at the moment. This has been an interesting poll.
    Mar 2006
    Brisbane, Australia
    11,472
    203 Post(s)
    1505 Post(s)
    Robotron isn't really a problem. Most people have a 2 player setup and map the joysticks. Firing is by joystick so no biggie.
    The problem with battlezone is that you really need 2 joysticks (2 hands) and then a fire button (3rd hand......forehead?). It makes for some awkward gaming unless one of those joysticks is a Top Fire.
    Brad
  1. Battlezone 'Instruction Card/Sticker' .. now vectored
    By spriggy in forum Aussie Arcade Artwork Resource
    Last Post: 4th November 2009, 04:22 AM
  2. Battlezone Repair Log
    By VectorGlow in forum PCB and Monitor Repair logs
    Last Post: 25th June 2009, 01:50 AM
  3. Battlezone Resurrection Repair Project
    By dezbaz in forum Arcade Technical and Repair Questions
    Last Post: 29th March 2009, 07:42 PM
