Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Thread: Adding of games to a cocktail machine
  1. #21
    Jan 2009
    Cairns
    13,851
    456 Post(s)
    3734 Post(s)
    Quote Originally Posted by theshagking View Post
    My appologies to everyone if I came across demanding anything. I had spent some time already trawling to get it working again. It is old but was hoping to keep it all the same. I will redo it and make it better, was hoping that someone may have had some knowledge as to what was being used.
    Once again if I offended I am very sorry. Cheers
    I don't think anyone was "offended" - just trying to explain that you will really be wasting your time trying to fix this when it was always, at best, a copy of a copy anyway.
    A multi-in-1 for $100 will do the same job (or better) and you will be up and running in minutes.
  2. #22
    Mar 2006
    Brisbane, Australia
    11,554
    190 Post(s)
    1441 Post(s)
    I'll just add that CF Cards are notoriously unreliable and flakey. You will be doing yourself a massive favour by replacing the unit in there with something infinitely more reliable.
    Brad
  3. #23
    Oct 2005
    Croydon, VIC
    1,956
    90 Post(s)
    330 Post(s)
    I'm 99.99% certain that this is one of RetroGame's cabinets, as I'm not aware of anyone else ever doing a PC based cocktail cab using a CF Card.
    To be fair, at the time his setup was the duck's guts and although there may be more reliable and economical solutions available now, there certainly wasn't back then!!! He used very specific PCs that had onboard sound that required no drivers, which meant he was able to use an extremely stripped out OS and run the GameLauncher frontend. The whole thing was actually quite ingenious.
    His main reasoning for using a CF Card instead of an old HDD was, that should problems ever occur, it would be a simple matter of posting out a replacement CF Card with instructions on how to swap them over, then the customer would be back up and running with a minimum of fuss. The only thing they'd lose is their high scores.
    I sold a few of his cabs, but not the later ones with the CF Card as he did those pretty much exclusively for what was Child Amusements (now Pinball Spare Parts Australia) who sold heaps of them!
    To the OP, I'm happy to track down Iain (RetroGame) and see whether we can get an image file for you. That way you could drop it onto an old IDE HDD, or maybe even get a replacement CF Card from him, to get you back up and running. It's all well and good to suggest that you swap over the "something more reliable", which is being translated here as a non-PC based solution, however there is likely to be a fair amount of cost and re-work involved in that to convert it over to something that may not necessarily be that much better.
    Let me know if you'd like me to contact Iain for you.
    Cheers, Chris
  1. Monday Pinball Questionaire
    By rod71 in forum Pinball History and Trivia
    Last Post: 29th December 2008, 02:08 PM
  2. Essential Arcade Games
    By Nidzdotnet in forum Arcade
    Last Post: 24th November 2007, 07:25 PM
  3. Cocktail Machine! Help needed!
    By sega rally in forum Arcade Technical and Repair Questions
    Last Post: 11th February 2007, 09:16 PM
