Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 23
Thread: Adding of games to a cocktail machine
  1. #11
    Mar 2006
    Brisbane, Australia
    11,554
    190 Post(s)
    1441 Post(s)
    Definitely sounds like the cf card is toast. I'm unfamiliar with these systems, all the ones I might build use a proper HDD but you'd need a new CF card and then at the very least the roms to match the version of Mame it's using. First question to ask is does it use a HDD as well?
    Brad
  2. #12
    Mar 2013
    Truganina, Victoria
    7,574
    398 Post(s)
    2775 Post(s)
    cf might have once had multiple partitions ?
  3. #13
    Jan 2009
    Cairns
    13,851
    456 Post(s)
    3734 Post(s)
    Wasting your time trying to resurrect this POS.
    It will likely be far cheaper and certainly faster to buy a new multiboard - $60~199 will do it and you are up and running again.
    One link here but there are dozens more:
    https://www.diyarcade.com.au/all-game-boards
  4. #14
    Dec 2014
    South Australia
    7
    3 Post(s)
    I have never seen a CF style system before.....I was hoping to extract the data off the card, but alas as I said it is not working in my flash reader. I am very familiar with other boards etc, was hoping to just get this working as is......without having to spend any extra $$'s on it.....
  5. #15
    Jun 2008
    Brisbane, QLD
    2,583
    252 Post(s)
    502 Post(s)
    That mobo is definitely way past it's time, chuck a P4 or later PC in it with a 20+ gig HD and run Mame with Mala frontend if you must have the ability to add games.
    You could also run an Raspberry Pi but I know nothing about setting those up.
    Otherwise just put a 60in1 or other multi board as previously mentioned.
  6. #16
    Dec 2014
    South Australia
    7
    3 Post(s)
    I know it would be easy to put in a PI or something else, but was wanting to keep it original. Does anyone have any files etc that could help me recreate this?? In the DOS DIR I can see GLAUNCH......which has a MAME folder in it. A CRYSTAL folder which has a mix amp sound card set up + a few auto exe files etc. Was hoping to get this one back up as is, it is a cute little unit
  7. #17
    Mar 2013
    Truganina, Victoria
    7,574
    398 Post(s)
    2775 Post(s)
    Quote Originally Posted by theshagking View Post
    it was never original really. it was born a bodgy pc based copy of the real thing.
  8. #18
    Jun 2008
    Brisbane, QLD
    2,583
    252 Post(s)
    502 Post(s)
    I'd suggest if you want to keet it 'original' then do some research and take the time to learn how to ser it up/fix it yourself.
    You'll be hard pressed to find someone who has the exact files you need, it will more so be a case of you having to trawl the internet for hours finding the right info and files to get it back up and running.
    Glaunch is a front end called Game Launcher which was the first front end I used back in 2005.
    Good luck.
  9. #19
    Feb 2016
    1,211
    17 Post(s)
    512 Post(s)
    Quote Originally Posted by Homepin View Post
    Piece of software?
  10. #20
    Dec 2014
    South Australia
    7
    3 Post(s)
    My appologies to everyone if I came across demanding anything. I had spent some time already trawling to get it working again. It is old but was hoping to keep it all the same. I will redo it and make it better, was hoping that someone may have had some knowledge as to what was being used.
    Once again if I offended I am very sorry. Cheers
  1. Monday Pinball Questionaire
    By rod71 in forum Pinball History and Trivia
    Last Post: 29th December 2008, 02:08 PM
  2. Essential Arcade Games
    By Nidzdotnet in forum Arcade
    Last Post: 24th November 2007, 07:25 PM
  3. Cocktail Machine! Help needed!
    By sega rally in forum Arcade Technical and Repair Questions
    Last Post: 11th February 2007, 09:16 PM
